window remote control question
Old Oct 30, 2000 | 06:16 PM
jljon
the past models allowed you to lower windows with the remote. when and why did that get dropped? it was handy. anyway to access it in the 2001 models.
Old Oct 30, 2000 | 06:52 PM
TimW's Avatar
The silent but deadly Moderator
dropped with 2K...
I cannot rell you why. I envy the Passat/A4 owners too.
Old Oct 30, 2000 | 07:17 PM
xtantmaxima's Avatar
Re: dropped with 2K...
Mine does! And those cars only do it through the key.
Old Oct 30, 2000 | 07:21 PM
mingo's Avatar
Re: Re: dropped with 2K...
u got the window roll down module with your alarm??
Old Oct 30, 2000 | 07:35 PM
Re: Re: Re: dropped with 2K...
hell yeah, up and down in front and back.
Old Nov 2, 2000 | 09:48 PM
ander
How?
How'd you get your windows to do that?
Old Nov 3, 2000 | 07:42 AM
Clifford SmartWindows4. Module for the alarm. Set you back $150 per set installed. Very conveinent. When you lock your car (re: set the alarm) rolls your windows up for you. If its hot, hit a button and it vents em. Hit it again, vents more, hit it one more time, and you're about half way down. You only get three vents.
Old Nov 3, 2000 | 07:46 AM
JMax2K's Avatar
That module hooks up directly to the Nissan system? or that is for an aftermarket alarm system?
Old Nov 3, 2000 | 09:21 AM
There are systems that can be programmed to do just this function, but I think that they only give you one direction control. Also, you would have to carry around an extra remote. The other benefit of the Clifford system is that all my windows now have auto up/down feature when you're driving.
Old Nov 3, 2000 | 10:08 AM
xydavid's Avatar
How does the auto up/down work while driving? Do you have to use the remote?
Old Nov 3, 2000 | 12:00 PM
no, the reason that the module is so expensive is that wires have to tap into each doors window switch. when a signal is sent the module overtakes control. It is a real slick system, just time consuming for the install. If you don't want the windows all the way down, there is a slight delay, but no problem. The easiest and fastest way to get a half open window is to tap it, then tap it again when you want it to stop. i love it.
Old Nov 4, 2000 | 02:10 AM
warrlocked's Avatar
I wondered the same thing! I had a '97 Maxima with remote keyless and you could roll down the front windows by holding down the "unlock" botton on the remote. I couldn't believe that they left this nice touch off of my new 2000 Maxima. But, if you will all notice, Nissan went cheap in other areas of the 2000 Max. Power door lock logic: On my '97 Max you could lock all the doors by locking the manual "lock" flap on the front doors. You can't do this with the 2000 Model. And what is up with the "auto" selection for the headlights. I assumed that the system would leave the headlights on for a period of time (30-40 seconds) after you turned off the ignition.....but it basically just turns them on when it gets dark and turns them off when you turn off the ignition. I was disappointed in these certain little areas but I Love my car overall.
Old Nov 4, 2000 | 10:49 AM
You CAN lock all the doors this way, you can also open them this way, turn right twice. In regards to the headlights, well at least they turn on right? That's all I care about. Who needs their headlights on after you get out of the car?
Old Nov 6, 2000 | 11:23 AM
eroleyikan
remote with sunroof
Can the sunroof be wired/programmed to close when locking?
Old Nov 6, 2000 | 05:30 PM
xydavid's Avatar
it's a safety feature
This was actually intentional. They do it so that you can independently lock and unlock individual doors.
Old Nov 6, 2000 | 05:32 PM
ander
I don't think so.
The 2000+ is still able to unlock first the drivers door, and then the passenger doors, just like the 4th gen.
Old Nov 6, 2000 | 05:38 PM
the alarm has a built in output that could be integrated into the sunroof. the reason that it would work is because the auto closure is just a pulsed switch that it has to activate once. if you have to hold the button down (old cars) then it could be a costly procedure.
Old Nov 6, 2000 | 05:40 PM
xydavid's Avatar
Re: remote with sunroof
Actually you can. Although one installer recommended I not do it. But I think he was just afraid to because (at the time) he had no documentation nor experience with the 2k Max.
If you do it, just make sure you find a good installer who understands electronics and motors and isn't just reading the installation book that came with the alarm or module. You want someone who's going to go out of his way to do it safely and RIGHT so you don't end up burning up motors, relays, and otherwise just f**king **** up. Bad thing is: the good installer probably won't come cheap, but s/he will take the time to do it right.
ah2002
Mar 9, 2016 01:42 PM
Mario Vegas
Oct 5, 2015 11:10 AM
doctorpullit
Aug 20, 2015 05:15 PM
shaunkey1
Aug 18, 2015 10:09 PM
maximaham
Aug 7, 2015 01:11 PM
