2K2 Hi/Lo Beam fix yet?
Re: 2K2 Hi/Lo Beam fix yet?
Originally posted by maxse01
Put my 2K2 headlights in today and i was wondering if you guys figured out how to fix that problem with turning the xenon's off when you hit the high beams? Just wondering. Thanks.
Re: Re: 2K2 Hi/Lo Beam fix yet?
Originally posted by IceY2K1
I don't have that problem. Check the Sticky How-To Thread for directions.
Just look at my Writeup, the picture shows what needs to be done, The writeup may be off due to the fact I cant access the server since it is down.
Dixit
not to sound like a lemming, but what about the flickering problem of the indicator lamp? i know alex had a theoretical wiring plan utilizing relays, but has it been done? i have the relays and all sitting in my room and the clip for the headlights are gonna get picked up tomorrow =D
thanx in advanced.
thanx in advanced.
thanx in advanced.
thanx in advanced.
Originally posted by BigDogJonx
Are you having this flicker problem with the high beam indicator? Cause I heard him talking about it but I dont have that problem.
thanx in advanced.
thanx in advanced.
The relay setup(v2.0) will work fine. After I go to the dealer and I reinstall everything I will add the relays for sure. Trust me, they will work fine.
Re: ?
Originally posted by TimW
is there a write up on using relays yet?
Basically, mount the relays as close to the battery as possible. Supply power and ground to the correct terminals. The H4 plug Terminal #1 opens/closes the relay for the High beams.
Yes, serin used the relays and he didn't report anything fishy.
Re: is it the HIDs or the H4's
causing the flashing light? I thought it was feedback/bleed from the ballasts.
On one side of the High-beam indicator you have BATTERY and on the other side you have the combo switch. When I originally thought of this setup I ASSUMED the combo switch would be OPEN. However, they're is apparently some resistance in the switch or something else providing a slight path to ground, thus causing the faint blinking.
The relays will eliminate the combo switch as a path to ground, thus eliminating the indicator blinking. You won't need diodes.
Re: coo.... thanks...
say.. any reason you wouldnt put both headlights on one (beefy) relay? (+12v switched, grounded at each light).
Again, there are SEVERAL ways to wire this system. I just chose one and ran with it. You guys might combine parts of Dixits' install with mine or maybe go with Hogans'. You guys have the advantage of knowing several ways to do this, so use what's best for you.
I'm not even done yet. I still have to add relays and I'm adding a 7-fuse block that combines with 3-4 relays, so I can power the HIDs, Hella Horns, and more later on. This setup is definitely going to evolve over time. Please keep the feedback coming though on my installation directions.
yeah yeah.. I know...
and as one of the few people who've done the install (and have the FSM), I really appreciate your insight. At this point, I'm trying to make my install as clean as possible and eliminate any chance of losing my lights at speed on a desolate highway no really, just plan on taking a very conservative approach, even as bad I want to hook them up. As much as the lights are (to buy AND to replace) I want to save them from any possible power problems and not have any reliability issues. Long story short, me = wuss..
you and Jonx are like the John Appleseeds of 2k2 HIDs
I have a question about the wiring. Will the stock wiring be able to handle both the Hi and Lo beam being on at the same time? I don't want to be melting the harness and the wirings. It just seems like it would put tremendous power through the wires.
Re: ..
There is MINIMAL chance of power handling problems, because I have LESS power than stock running over the stock harness.
Re: Re: ..
Originally posted by Keh mon
Anyone know what the wiring harness's are like on the 2K2 maxima? If they're the same as ours, then we prob. wouldn't have any problems. And I definately agree with TimW that I'm a wuss about doing all this. I don't want to ruin the lights or fry anything else. The easier the install, the better for me.
Re: Re: Re: ..
Originally posted by 2maxguy
Harnesses on the 2002 are different. HID low beam and 9005 high beam each have their own feed and own fuse in the under-hood fuse/fuselink box. In addition to the fuses in a 2001 (fuses #68&69), the 2002 also add fuses in spaces #54 & 55. When assessing how large a load is, keep some basic electrical formulas in mind. Watts = volts X amps is useful or Amps = watts / volts (Ex. a 60 watt high beam draws 60/12volts = 5 amps. One Hella #87106 relay rated at 30 amps DC can easily switch two 60 watt lamps (5+5=10 amp load) with a safety factor of three. Also keep in mind fuses are sized to protect the wire from overload, not protect the device. Make sure wire gauges are adequate and fuses are sized properly.
TallTom
50
07-08-2022 09:54 AM
