Time for new tires, would these fit?
Old Oct 9, 2001 | 07:22 PM
nc00max
Since I have 30.5K miles on my original stock tires now, I'm looking to upgrade and put on some new ones int the near future. I checked out tirerack.com and saw a set of Kumhos that I wanted, but they're 245/50/16's. I plan on lowering the car here sometime sorta soon with the H&R kit, so it's going to make any fitting even more difficult. Would these still fit with the H&R's or should I look smaller and narrower?
Old Oct 9, 2001 | 08:02 PM
Paul6speed's Avatar
That's too wide. 7" is the minimum for that tire size. You have 16" rims, right? Those are 16 x 6.5.
You can put on 225/50R16 or 215/55R16.
Old Oct 9, 2001 | 08:10 PM
2001SE's Avatar
he can buy new rims...that will solve his problem...
Old Oct 9, 2001 | 09:14 PM
BigDogJonx's Avatar
7" minimum CANNOT fit a 245 safely at all. There has been a HUGE controversy with the 235 trying to fit on a 7" wheel and it is not recommeded by the DOT TIRE.
As a mattery of fact here is the EXACT SPEC TAKEN FROM KUMHO
245/50WR16------SIZE
1609lbs.-------MaxLoad
44psi-----------MaxPSI
10/32nds----TreadDpth
7.5" ------Rim(W) Minimum
Dont believe me, why not go and check out the specs at kumho yourself, Kumho Supra 712 SPECS
Do not put a 245 on a 7" rim, you are risking safety. If that is what you want to do, it is your car.
Dixit
Old Oct 10, 2001 | 04:45 AM
UMD_MaxSE's Avatar
Got Bent?
on the stock 16's, don't go wider than a 225....
Old Oct 10, 2001 | 05:43 AM
nc00max
Thanks for the input. The last thing I wanna do is endanger the car, but I figured I'd ask anyways. I wanna go a little wider, so I'll probably get the 225's. Will these throw off the speedo much?
Old Oct 10, 2001 | 05:51 AM
BigDogJonx's Avatar
Stock tire being 215/55/16 moving to a 225/50/16 is going to throw your speed too fast by 1.8%
Now if you move to a 235/50/16 it will only throw your speedo too fast by 0.2% But then again you SHOULD not put a 235 tire on a 6.5" width rim.
Dont worry about the 1.8% and stay safe.
Old Oct 10, 2001 | 06:58 AM
Paul6speed's Avatar
To see the size differences and its effect on your speedometer, go to http://www.miata.net/garage/tirecalc.html
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
twotonezed
Aug 16, 2015 11:41 AM
