Eibach Install Help!!!!
Old Oct 12, 2001 | 06:28 PM
MAX2000JP's Avatar
Can somone write a quick install write up or direct me to a link on the proper way to install springs on a maxima?? My friend has done springs, but not on an import. They should be the same, but I wanna make sure its done correctly so I dont have any squeeks or weird noises coming from the suspension. How long do you guys estimate it will take with 3 guys working on the job at once???? Any help would be appreciated! Thanks
Old Oct 12, 2001 | 06:33 PM
MaDxKiLLa's Avatar
i itnk its in the HOW TO IMPORTANT thread thing
Old Oct 12, 2001 | 08:23 PM
theMax's Avatar
Re: Eibach Install Help!!!!
this site might help
http://integra.vtec.net/geeser/megamax/springs.html
Old Oct 13, 2001 | 09:56 PM
CHI99Limited's Avatar
Do you need to get an alignment after you install a set of springs??
Old Oct 13, 2001 | 10:25 PM
RBa's Avatar
RBa
You're suppose to but some ppl haven't and still survived.
Old Oct 14, 2001 | 05:52 AM
MaDxKiLLa's Avatar
you should get an alignment after ur springs have fully settled...it should be in about a month
Old Nov 12, 2001 | 03:13 PM
rob van dam's Avatar
another question
ive had my eibachs for about 2 weeks....i have put liek 400 miles on them.....WHEN WILL I KNOW THE SPRINGS HAVE SETTLED.....???...SHOULD I GET AN ALIGNMENT NOW?
Old Nov 12, 2001 | 05:39 PM
RBa's Avatar
RBa
Re: another question
No.. Wait until you feel you really need one!!!.. Like I said b4, You'll survive!!!....
Old Nov 12, 2001 | 07:59 PM
BigDogJonx's Avatar
Spring/Strut Swap
You gotta do this with someone who has done springs before. The first time I did it with my friend it took us about 8 hours (no air tools and no lift). I did struts this weekend with Tim's help and it still took 4-5 hours.
The short of it is:
For rear:
1. Jack up rear end of car and put it on jackstands (or use a lift). Note: Don't jack it up by the axle or you'll have "fun" getting it back together.
2. Remove the rear wheels.
3. Remove the trunk liner.
4. There are 3 bolts on top of each strut. They can be found where the trunk meets the back seat.
5. Figure out some way to remove them (I used 2 socket extensions together. They are 14mm. Remove the outter 2 bolts, leaving the one in the center.
6. Remove the larg bolt connecting the strut to the axle (will need a breaker bar or equivalent).
7. Compress the spring.
8. Remove the top hat (thats the middle bolt).
9. If you are replacing springs, compress the new spring and then put it back on the strut.
10. Do steps 1-9 in reverse.
For front:
1. Jack up front end of car and put it on jackstands (or use a lift).
2. Remove the front wheels.
3. Slightly loosen the center bolt on top of each strut.
4. Undo the 3 bolts around top of each strut.
5. Undo the two big bolts at the bottom of the strut (will need a breaker bar or equivalent).
6. Remove all the brake line clips from the bottom of the strut (there is a total of 3).
7. Remove the strut assembly from the car.
8. Compress the spring.
9. Remove the top hat (thats the middle bolt).
10. If you are replacing springs, compress the new spring and then put it back on the strut.
11. Do steps 1-10 in reverse.
Courtesy of Punkdork.
Server is busy
MaxLife17
Jun 27, 2019 01:37 PM
imported_Nismo_max
Feb 17, 2016 03:39 AM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
