wierd noises commin from drivers side!!
Old Sep 16, 2007 | 10:03 PM
BLACKKILA.GTR's Avatar
im gettin a wierd rumbling noise from my driver side wheel when i first start driving after a lil bit it goes away , i can still feel it a tad bit in the wheel but not as bad....but if i come to a stop and take off again it comes back....i thought wheel bearing....changed that i thought tie rod...changed that still nothing..i took the axle out of the tranny and examined it but it seems fine.....
anyone have any imput//?
Old Sep 17, 2007 | 03:43 PM
Keyoh's Avatar
Could be the front sway bar end links. I'm having the same problem now too and I'm hoping if I replace them it will go away.
http://www.carsurvey.org/viewcomments_review_71793.html
Old Sep 18, 2007 | 01:23 PM
bluefire's Avatar
sounds like tierods or sway links. my advise dont go cheap on the sway links, its not worth the few bucks you save.
Old Sep 18, 2007 | 06:33 PM
icemanf14d's Avatar
Sunlit Sand Beauty
ive been getting similar noises for a few days. only happens from 20-0 mph and from 0-20...then the rubbing noise goes away, though i feel the rubbin itself and am getting vibrations. idk what it is...but it may b the same prob u have
Old Sep 19, 2007 | 05:01 PM
man ive went to a couple of places and got some bs responses....like my axel is too short..wtf...lol but i dunno ima order those sway links and change em out...any body got a site i can get some good ones from??
Old Sep 19, 2007 | 05:22 PM
maximadave's Avatar
detailerdaveb@gmail.com
what kind of miles do you guys have?
Old Sep 19, 2007 | 06:30 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
I've got 120k and I just ran into this problem. It's as if the damn wheel is about to come off. Thin it just goes away. Vibration only happens when I hit the gas... when I let off it smooths out.
I was thinking maybe it was the bearings, maybe my cv joints??? Any help would be appreciated.
Old Sep 20, 2007 | 01:40 PM
67.000
Old Sep 20, 2007 | 05:57 PM
Torgus's Avatar
i have the same problem and i hate it!
i only have 45k on her.
i was thinking bent rims but it really only under acceleration that i notice it. cruising it's fine. and if i throw it into N it goes away.
Old Sep 23, 2007 | 11:41 AM
IT MIGHT JUST BE OUR CV AXELS
Old Sep 23, 2007 | 11:26 PM
MaxBoost925's Avatar
Drug Money
Yeah it is - I had mine lower than yours. But when i raised it back up - immediately the clicking/rattling sound disappeared.
Old Sep 24, 2007 | 07:14 AM
KRRZ350's Avatar
Rotating the wheels might not be a bad idea, are they feathered at all or can you find any bumps? Tires heat up after driving regardless because of the constant compression at the 6 o'clock position.
Old Sep 25, 2007 | 04:59 PM
MaximusMorpheus's Avatar
I think I am getting the same noise, resonating sound when the wheel turns . It only happens in the morning when I first start driving but goes away after like driving for 5 seconds. I need to find out what that is, kinda of annoying.
Old Sep 25, 2007 | 09:35 PM
word? hmm ima try raising it up and see wat happens....... thanks for the info
lower than mine?
i see u on myspace (if u want add me mrdrkngood@hotmail.com) cant get to my page right now or i would add u (stupid government computer)...
Old Sep 25, 2007 | 09:59 PM
seby86's Avatar
dammit..why couldnt they have just made the maxima RWD? alot of front end problems prolly could of been avoided altogether.. i'm sick of all these front end issues and noises.. lol, i'm jk.......
then again if maximas were RWD, then we would be some cocky sob's for sure..
Old Sep 26, 2007 | 02:32 AM
Drug Money
Aren't we already? The constant "Honduhs suck"
Old Sep 26, 2007 | 05:14 AM
SuperStasiu's Avatar
Why not take out the axle and take it apart to check out how the ***** and the inside of the joint look. Its not hard, just slide the rubber up, have someone hold the smaller end or part that goes into wheel bearing, then wack that with a rubber hammer pretty hard on different sides it should pop out. Then examin the condition of the joint, im gonna say theres wear on ***** and that thing they sit in, thats why your getting a noise
Old Sep 26, 2007 | 11:37 AM
seby86's Avatar
thats what i'm saying. we're already cocky....imagine how much more we'de be...
Old Sep 26, 2007 | 06:05 PM
Orgullo's Avatar
cv axles from raxles... $174.00 each a piece.
Boost you went with raxles right? Have you had any issues since installing them?
Drug Money
no problems, they're sexy.
they just don't like to go TOO low. They start rattling/clicking.
Old Sep 26, 2007 | 06:29 PM
Orgullo's Avatar
How low is too low??? I raised the car up to about the ride height your at right now. It's about 25 from the center of the fender to the ground in the front and about 26 in the back. Too low???
Drug Money
Try 23.5 inches?
Old Sep 26, 2007 | 06:49 PM
Orgullo's Avatar
Not I... lol that is Blackkilla. So I should be straight at my ride height? What are you at right now?
Old Sep 26, 2007 | 11:49 PM
Drug Money
Right now I'm at 25.5 driving height lol.
At the show's i'll probably hit 22 inches.
Old Sep 28, 2007 | 07:41 PM
uggghh can i do 24??? lol, yeah ima have to come up dont wont to but ima do it....but for shows slammed like a bit$ch....
Old Sep 28, 2007 | 07:52 PM
nsnrider's Avatar
check your tires, mine always make the rubbing noise when the pressure is too low.
boomerbrian
Oct 31, 2018 10:25 AM
AcuraLegend
Oct 17, 2016 08:47 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
