Wilwood calipers: use the red ones they sent me?
Old Nov 14, 2007 | 07:14 PM
  #201
n3985's Avatar
大陆弟弟
So back to my question, did they include the spacers as stated? And what sized spacers did you use? Thanks irish
Old Nov 14, 2007 | 07:16 PM
  #202
SoonerFan's Avatar
Cletus
Originally Posted by joebangaa
Why do you keep posting pictures of your car?
some people have not learned how to create a sig...so they post a pic in each post...really annoying when people reply and quote the pic.
ive told him several times
Old Nov 14, 2007 | 07:18 PM
  #203
Shogunsc4's Avatar
i purchased those "custom brackets" supposedly specialized for our maximas from the nyc forum....long story short....those damn brackets have mounting holes not drilled to spec. The screw holes were too small to match the hub mounting holes and too small to fit the oem bolts
Old Nov 14, 2007 | 07:19 PM
  #204
Shogunsc4's Avatar
no spacers included.
Old Nov 14, 2007 | 07:20 PM
  #205
redmaxpa007's Avatar
i SeE what you did therE
:attention
Old Nov 14, 2007 | 07:59 PM
  #206
irish44j's Avatar
retired moderator
Originally Posted by ShiftVQ35
soounds like that is a lame excuse to me. they dont want to spend more time making specific brackets that center it. all 4 pistons have to move exactly the same
even with the caliper off-center, all four pistons move at the same time. Offsetting the calipers (wilwoods in particular) has been done for years and years in the classic/muscle car scene, since older/smaller wheels don't have s much clearance.
I didn't notice any. then again, I wasn't looking for them so might have thrown them out for all I know. I just used some washers that I was previously using as shims on the z32 calipers.
It has been dealt with.
interesting......
Old Nov 14, 2007 | 08:53 PM
  #207
ShiftVQ35
hub mounting holes? there are no threads for bolts in the knuckle. it is a straight hole. i bought the brackets from that member and my install was simple. however i did buy new bolts for the brackets because the buyer told me that the threads in the brackets are not metric and the stock hardware wouldnt work. so i went and bought 4 bolts. are you sure you are installing the brackets correctly? the way i installed it, was the new bolts went through the knuckle hole and threaded into the bracket. post pics. and irish44j i dint say that the pistons moved at different times, i said one side moves more then the other side if the rotor isnt centered. wheel clearance = wheel spacers
Old Nov 15, 2007 | 12:17 AM
  #208
Shogunsc4's Avatar
being that the mounting holes are bigger in the knuckle and that you are using smaller diameter bolts thru these holes...how secure is it? Will it move around under extreme braking conditions?
Old Nov 15, 2007 | 11:19 AM
  #209
ShiftVQ35
if this makes sense, the mounting holes in the knucle and in the bracket are the same. the reason oem 14mm bolts dont work in the bracket is because the threads are standard not metric which is common
Old Nov 15, 2007 | 11:58 AM
  #210
1sexyleo
YELLOW!!!!!.......
Old Nov 15, 2007 | 12:18 PM
  #211
alicious's Avatar
the org...not what it was
Originally Posted by 1sexyleo
YELLOW!!!!!.......
ummm...your a few months late sweetie
Old Nov 15, 2007 | 07:23 PM
  #212
irish44j's Avatar
retired moderator
One side does NOT "move" more than the other. Each time you depress the pedal, they will move the same amount, regardless of where the caliper is centered. They don't retract more than .5mm or so when you lift off the brake pedal.
The issue comes up only when the pad is low on material, in that the more-extended piston could "pop out" in theory (depending on the offset), which is why pad shim spacers are used-to alleviate said problem. This is not rocket science. Like I have said many times, it is not uncommon for offset calipers (not centered on the rotor) on alot of backfit brake setups, including vintage racers. This is a FACT and I've never heard of it being an issue of concern.
Is centered better? Sure, for the simple fact that shims don't need to be used. But then you have wheel clearance issues - and wheel spacers are not the answer as they simply weaken the wheel-to-hub interface in many cases.
Old Nov 17, 2007 | 09:40 PM
  #213
skc's Avatar
skc
Black. Red are for Z06's and yellow is for Porsches.
Old Nov 18, 2007 | 12:35 AM
  #214
prius blue....
Old Nov 18, 2007 | 01:12 PM
  #215
irish44j's Avatar
retired moderator
to all you late arrivals....the red ones with th wrong piston bore were sent back long ago. Black ones have been installed, uninstalled for winter, and are currently sitting on a shelf in my garage.
enough with the color commentary!!!
aw11power
Oct 10, 2021 04:57 AM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
wiseguy6199
18
Oct 1, 2015 12:28 AM
