Slow Timing
Slow Timing
Standard timing for my 5th gen is set at 14 degrees. I checked mine and it was down around 10 degrees. I bumped it to 12 and have not had a chance to check it again since then. I can probably get ahold of a used ECU. Does anybody know whether swapping the ECU might help?
No, I mentioned nothing of dynoing. Use the logger, and log (record timing advance in *) a run through the RPM's. Then post the #'s. If you put down 190, I wouldn't be worried about it. But I would be concerned that peak is @ 5500.
yat70458
Aug 3, 2015 01:16 PM
