something i noticed
something i noticed
when ever i start my car i see the red oil light flickering at the same time i can hear the timing chain rattle. its been going on for a while, but ive been ignoring it. i havent been losing any oil, but its kinda annoying. is anyone else noticing this or just mine? i have a 3.5 BTW.
Well, this happened to me a decade ago in my fathers Jaguar. I was on the interstate and the oil pressure light was flickering on along with that sound you speak off. After I pulled off the interstate, the engine through it's rods through the oil pan and motor was destroyed. Luckily it was under warranty, but it's something you might want to get fixed soon.
Common chaps.......it takes about 9 - 12 psi of oil pressure at the LOP switch to put the LOP light out. The time for the pump to build up that pressure and put the light out on a start varies, and the light may flicker as the engine accelerates up to idle, particularly with low viscosity oils and a hot engine. With the Maxi, how good the oil filter drain back valve is working obviously has a lot to do with it as well.
TallTom
57
Oct 14, 2025 05:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
