"service engine light" came on,anyone had this b4?
Old Oct 20, 2001 | 07:58 AM
Whtmax'01's Avatar
I was driving on the highway yesterday and the "service engine soon" light indicator came on and wouldnt go off.
Anyone had same problem, what could it mean?
Old Oct 20, 2001 | 08:11 AM
UMD_MaxSE's Avatar
Got Bent?
could be anything... Did the car driv ok with the light on? Any mods? I'd take it in to get it checked out....
Old Oct 20, 2001 | 10:25 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Best way to find out is to take it to the dealer (or someone) that can grab the error code for you.
Old Oct 20, 2001 | 11:04 AM
jnovember's Avatar
Do a search on "Check Engine Light"
Lots of posts on this topic.
Old Oct 20, 2001 | 04:17 PM
Sly's Avatar
Sly
If there are no obvious problems, check the gas cap is on tight, 3 clicks minimum. Reset the ECU by unplugging the battery a few hours. If the light comes back on then take it to the dealer for a diagnosis.
Old Oct 20, 2001 | 04:45 PM
maxracer27's Avatar
Mine came on while racing on track. It was the throttle position sensor that went bad. It also felt like my transmission broke, I guess it just went on some kind of 'safe' mode. The part was on back order for 2 weeks, just got it fixed today.
Old Oct 20, 2001 | 10:20 PM
serin's Avatar
yeah. i just had it a couple weeks ago. initially i cleared it out then it came back on a week later so i took it to the dealer. guy there told me he reprogrammed ecu with updated exhaust parameters. it's been cool since then. but i understand it could be anything. pretty generic error. you'll have to pull the code off the ecu. take it to a shop instead of the dealer. the one i went to didn't charge me just for the code like the dealers sometimes will. they'll quote you on the work that needs to be done then charge for that.
Old Oct 21, 2001 | 06:35 PM
ChillWill2000's Avatar
My check engine light came on and I took it to the dealership and they hooked me up to the comp and discovered an O2(oxygen) sensor was bad in the exaust which they had to replace. No big deal...When the check engine light was on my car ran completely normal so I knew it couldnt be a big deal.
Old Oct 21, 2001 | 10:43 PM
vandi's Avatar
Could be little ...could be big .... bottom line ... get it in asap
shilov
Feb 19, 2024 09:40 PM
Pixel
Sep 15, 2015 05:53 AM
seesole
Sep 14, 2015 12:38 PM
Steven Orozco
Sep 12, 2015 10:41 PM
jfl330
Sep 4, 2015 01:44 PM
