HELP, new noise in front right wheel
Old Oct 21, 2007 | 08:47 AM
maxspeed96CT's Avatar
The original VQ...
So just to add to all the other 100 things wrong with my car, now im getting a crazy noise from the front right wheel.
Its a grinding/ scrathing noise this time. and It does it only when the car is rolling (no load) , i notice it mostly when rolling at around 10 mph or when rolling to a stop , but when i touch the throttle the noise kinda just disapears..
I thought it was the brakes, but the noise does not change at all if i touch the brakes or not. Plus rotors and pads are only 2 months old. I did take the wheel off and did a qwk look at the brakes, saw nothing tho ...
Im thinking axle? but then agian i thought axels only make noise on turns??
wheel bearing? but did realy have much play in the wheel?
Old Oct 21, 2007 | 09:17 AM
jdm01se's Avatar
Calipers grinding?
Old Oct 21, 2007 | 09:18 AM
getbigtony's Avatar
first thing i would check is the backing plate; might be rubbing against the rotor
Old Oct 21, 2007 | 09:24 AM
jdm01se's Avatar
It really does sound like your caliper is grinding to your rotor.
I had a same problem with my driver side rear, and spent about $400 for the job to be done. That included new calipers for the rear, and new pads, AND getting my rotor cut because the grinding had almost killed it.
Old Oct 21, 2007 | 04:36 PM
The original VQ...
after more investigation im pritty sure its the wheel bearing......
The noise is pritty loud, i checked the brakes and didnt see any accessive wear on any parts of the rotor, spun the wheel and watched closley, everything is perfect from what i can tell... and also when there is a brakes issue the noise usualy changes when u press and release the brakes, but for me the tone of the grinding does not change
From what ive read wheel bearings usualy makes a hummin noise, any one ever had one that made a grinding noise?
I do have some play in the wheel when i movd it around, but it wasnt much at all, dunno
Old Oct 21, 2007 | 05:00 PM
merlin2375's Avatar
never heard a wheel bearing make a grinding noise. Besides just checking for wheel play another good way to diagnose wheel bearings is to close all the windows, shut off the stereo and go for a drive. Take some hard rights and lefts (find a windy road) and try and listen for when the noise goes away.
If one bearing is worse than the other, or if only one is dead you'll be able to tell because when you go around the bend the sound will decrease or disappear. In other words if you turn left and the sound goes away then you know the right side is the problem and vice versa.
Again, never head a wheel bearing make a scraping noise. Usually it's a droning or humming like you said. I would second checking the heat shield behind the rotor, sometimes it gets bent out of shape and can make an awful noise.
hope this helps a bit
Old Oct 21, 2007 | 07:11 PM
nsnrider's Avatar
i defenitly agree with merlin above, wheel bearings don't make a grinding noise, if you had your brakes done lately then check the back plate behind the rotor, I had several cases where the plate slightly rubbed on the rotor and it made an AWFUL noise kinda like grinding noise especially at low speeds.
Make sure everything is tight too.
Old Oct 21, 2007 | 07:34 PM
The original VQ...
ya i know this is driving me crazy, i replaced this bearing last year, but after i replaced it , it still had alittle play , but dealer said it was ok to have some play so i left it at that??
But what i think could have happend, is i drove on the bad bearing to long and messed up the housing last time ? im not sure
I was thinking axle, but those only make noises on turns for the most part , correct?
im gona recheck the brake rotor plate agian tomoro just to make sure i uess...
But how could it just bend outa place out of the blue?
Old Oct 22, 2007 | 07:12 AM
seisen's Avatar
Possible noise solution
Check to see if the dust brake dust shiel is bent in and hitting the rotor.
Old Oct 22, 2007 | 01:55 PM
Max_Gator's Avatar
Wheel bearings do indeed make that sound.
BOTH of mine in the front did - I had the grinding/scratching sound. Never had the hum.
Get them fixed soon so that you don't kill the hub . . .
Old Oct 22, 2007 | 02:10 PM
808MAX-SPEC's Avatar
When you had the wheel bearing replaced, did they also replace the hub assembly?
On two different occasions when I had my bearings replaced, they also had to replace the hub assembly. Just a thought.
Old Oct 22, 2007 | 03:09 PM
The original VQ...
No i didnt, i just pressed out the bearing and pressed in a new one, and now my friend tells me i could have messed up the housing when i drove on the old bad beaing...
I took everything apart again today, the rotor is not touching the shield and isnt even close, and everything else with the bakes looks good too.
Also i noticed when the wheel was on, i put one hand at 12 o'clock and one at 6 o'clock, and there was a significant amount of movement/play so i think the bearing is bad, but im still not sure if that can be causing the noise, cause it is pritty loud / bad....
Gona order the bearing and houseing from dave b and hopefully it fixes the problem.
Old Oct 23, 2007 | 09:42 PM
erikgeis's Avatar
My car made the same noise and it turned out to be a bad wheel bearing. The axle nut had backed off and destoryed my wheels bearing. Noise pissed me off.
Old Oct 23, 2007 | 09:50 PM
MADE's Avatar
I concur and I wish I would have know this before I had to replace both.
Old Oct 24, 2007 | 07:44 AM
HotMaxx02's Avatar
YEP... WHEEL BEARING...
I had mine done 2 months ago(76,000 miles drivers side). It was BAD... metal on metal gringing at slow speeds.
I had to do the passender's side @ 40,000 miles.
I guess they were not desiged too well??
I actually got mine done at a local shop and they had to replace the bearing and machine a sleeve to fit it into cause the hub was warped. $175.00 parts and labor!!
Heck of a lot cheapper than buying a $400 hub plus install...
Old Oct 25, 2007 | 06:59 PM
The original VQ...
damm is the hub realy 400$$ ???
i plan on doin the work my self but i was thinking maybe ~200 for the hub, ~60 for the bearing
Old Oct 25, 2007 | 07:21 PM
SuperStasiu's Avatar
Dude get that stuff through dave b i got mine hub and bearing through our local guy in chicago and it was like 220 for both i think maybe less then you just get the stuff pressed in for like 30-40 bucks
Old Oct 30, 2007 | 08:35 AM
The original VQ...
Finally got it changed , noise is gone and car drives alot smoother, but i think i need an aightment now car pulls alil to the right....
dave b didnt answer my pm, so i got it local paid about 180 total for everything from hartford nissan, and then 40 to press it in.
thanks guys
Old Oct 30, 2007 | 09:16 AM
Old Blue 66's Avatar
MIne was making all sorts of noises when the bearings went bad. Of course I lte it go WAYYY to long and the wheel was just wabbling all over the place when I finally got around to it.....
Matt93SE
May 24, 2019 02:58 PM
boomerbrian
Nov 8, 2015 05:10 PM
Starrider
Sep 17, 2015 07:26 AM
homeyclaus
Sep 3, 2015 06:15 PM
official_style
Aug 29, 2015 10:10 AM
