Engine Block
Old Oct 26, 2007 | 07:26 AM
tmuscedere's Avatar
Engine Block
There used to be a company that was producing high performance 3.5 engine blocks. Does anyone know the name of the company or if its still operating?
Old Oct 26, 2007 | 07:28 AM
SoonerFan's Avatar
Cletus
why do you need a better block?
can you afford it?
http://www.cosworth.com/shop_item.php?productid=464
Old Oct 26, 2007 | 07:34 AM
NmexMAX's Avatar
dot dot dot ...
is a High Performance Block? Higher Nickel content?
Old Oct 26, 2007 | 07:35 AM
SoonerFan's Avatar
Cletus
Nissan VQ35DE (350Z-G35) High Performance Short Block 3.5L The Cosworth VQ35DE high performance short block is the perfect foundation for your high performance application. Each High Performance Short Block is hand assembled by one of Cosworth’s skilled engine builders to exact specifications utilizing all new components and is available in either high compression 11:1 or low compression 8.8:1 for turbo or supercharged applications. To ensure smooth operation throughout the entire RPM range, each rotating assembly is carefully balanced, an essential requirement for high performance VQ35s. Additionally, comprehensive build sheet listing all critical dimensions is included. Use with our CNC ported Big Valve Cylinder Heads for maximum reliable performance.
Old Oct 26, 2007 | 07:37 AM
Iceman420's Avatar
(insert witty one liner)
It's real shiny though...
Old Oct 26, 2007 | 07:38 AM
NmexMAX's Avatar
dot dot dot ...
Yeah, just read the link .
But, those items are not block specific, this thread seems to be block specific
Old Oct 26, 2007 | 07:44 AM
DrunkieTheBear's Avatar
Turbo'd Saab
http://turbokits.com/350Z_turbo_kits.html
towards the bottom of the page they have engine internal parts.
Old Oct 26, 2007 | 07:46 AM
SoonerFan's Avatar
Cletus
its block specific (and all the internals)
Old Oct 26, 2007 | 07:48 AM
SoonerFan's Avatar
Cletus
actually, looks like thats just a nissan block with cosworth internals
Old Oct 26, 2007 | 07:49 AM
Turbo'd Saab
I have to ask...What in gods name do you plan to do?
Old Oct 26, 2007 | 07:51 AM
Stardust's Avatar
F---ing Kangaroos
MAYBE just maybe that motor won't burn oil.
NmexMAX's Avatar
dot dot dot ...
28 PSI + 11.5:1 CR.
SoonerFan's Avatar
Cletus
thats what i asked.
does he need it (or want it) and can he afford it.
Old Oct 26, 2007 | 07:52 AM
SoonerFan's Avatar
Cletus
dont need the whole engine block...just their rings (which is what im planning to do)
Kyle00's Avatar
WSH for teh cup
Originally Posted by NmexMAX
28 PSI + 11.5:1 CR.
Thats scary.
Old Oct 26, 2007 | 07:55 AM
NmexMAX's Avatar
dot dot dot ...
Do a franken/hybrid.
DE meets HR. Call it a DER
Stardust's Avatar
F---ing Kangaroos
I know but why not just start from scratch and up the CR in the process? Its only money and you cant take it with you.
Old Oct 26, 2007 | 08:53 AM
Turbo'd Saab
According to nissan, both the 30 and 35 can handle up to 12 lbs of boost. Honestly why would you want more then that. After 10 lbs your just crazy cause of torque steer issues and the car being a FWD.
Old Oct 26, 2007 | 08:55 AM
NmexMAX's Avatar
dot dot dot ...
Got a link?
Old Oct 26, 2007 | 09:32 AM
Turbo'd Saab
Got a link?
Are you still mad at me?
Besides numerous sources around here on the org and on the internet have said that the most you could or should possibly run before seriously considering replacing internals, is at 12 lbs.
Old Oct 26, 2007 | 09:33 AM
NmexMAX's Avatar
dot dot dot ...
refresh my memory.
I just found it interesting that you said that NISSAN said. That's all.
Old Oct 26, 2007 | 09:43 AM
Turbo'd Saab
refresh my memory.
well you haven't called me in a while, I miss our midnight chats on the PMs about that 3.5" intake setup I am doing, I'm working on boring the TB to 68mm versus the 55mm.
I just nissan, cause everyone else said nissan when they qouted the 12 lbs. I am a bandwagon loser I know
Old Oct 26, 2007 | 10:08 AM
NmexMAX's Avatar
dot dot dot ...
Why not try a PFTB set-up? Ahh yes, those lonely nights
, stock is 2.17" ? ? ? ?
Old Oct 26, 2007 | 10:56 AM
MaxBoost925's Avatar
Drug Money
ahahahahaha. durrrrr
Old Oct 26, 2007 | 12:51 PM
NmexMAX's Avatar
dot dot dot ...
That's what you tell them after they ask you your mod list
Old Oct 26, 2007 | 01:56 PM
HotMaxx02's Avatar
Kinda off topic... How Bada$$ could a N/A VQ be??
Would a Brian Cower 4.15L Stroker Kit(or Jun 3.8L) along with built internals, fuel delivery, ECU etc...($10,000-$15,000 worth of goodies)Do you any good for a N/A application??
Or is a Stroker Kit Specfically usefull for Forced Induction???
Old Oct 26, 2007 | 02:03 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by HotMaxx02
Old Oct 26, 2007 | 02:31 PM
SoonerFan's Avatar
Cletus
wow....off topic...AND all over the place.
Old Oct 27, 2007 | 12:11 AM
Drug Money
I didn't get that one. I'm slow
..seriously, I didn't get it.
Old Oct 27, 2007 | 01:16 AM
NmexMAX's Avatar
dot dot dot ...
Ok, scenario:
They ask you TF are your mods, you reply, duuuurrrrrrrr ..
shilov
Feb 19, 2024 09:40 PM
6spd4dsc
Mar 4, 2016 05:19 PM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
seesole
Sep 14, 2015 12:38 PM
