Requesting picture of VQ35 6sp fidanza flywheel
Old Oct 30, 2007 | 07:54 PM
coinage's Avatar
i am looking for a picture of the fidanza flywheel... i just need a pic of the top (friction) side and one of a close up of the bolt holes.
Thanks,
Matt
Old Oct 31, 2007 | 04:56 PM
ShiftVQ35
i have some pictures of it on my desktop so i will upload them for you. are you having problems with it ? make sure you get the timing correct when installing it
Old Oct 31, 2007 | 05:17 PM
absoundlab
I did a jwt clutch and flywheel in a 06 350z yesterday I should have took pics. sry
Old Oct 31, 2007 | 07:12 PM
coinage's Avatar
i just want to see if the 350z ones are the same or not... from absoundlab's post it sounds like they are...
just want to confirm
Old Oct 31, 2007 | 07:25 PM
absoundlab
ya its the same flywheel for a fwd maxima or a rwd 350z you just have to line up the correct hole on the flywheel to the pin on the crank thats all
Old Oct 31, 2007 | 07:55 PM
coinage's Avatar
alright cool.thats what i thought after i read about the 2 holes.. thanks
Old Nov 1, 2007 | 05:31 AM
L.M.L.
here is somethig i could find..
Old Nov 1, 2007 | 06:55 AM
Derrick2k2SE's Avatar
Are you sure? I know it will bolt up but I think the ring for the crank shaft position sensor is different.
Old Nov 1, 2007 | 07:54 AM
coinage's Avatar
i know they have the same part number, just one ends in fwd and the other is rwd....
in that pic in post #7, i dont see the timing holes...? sure that is for the 3.5?
Old Nov 1, 2007 | 10:07 AM
absoundlab
derrick yes im sure the 3.5 flywheel for a maxima is the same for a 350z. and coinage the 2 holes im talking about are on the back side of the flywheel
Old Nov 1, 2007 | 04:40 PM
ShiftVQ35
yes that picture is of a 3.5 fidanza flywheel
here you go
http://forums.maxima.org/showthread.php?t=543060
Old Dec 6, 2007 | 06:45 PM
coinage's Avatar
This is what JWT said
There is a big difference with the rear wheel drive flywheel and front wheel drive flywheel. Besides the difference in the dowel hole in the flywheel (JWT flywheels for the VQ35DE already have both holes there but one is epoxy closed), the encoder disc on the front of the flywheel (for the crank angle sensor pick-up), is different between the two flywheel applications.
So, would it be possible to use the 350z/G35 CPS? to avoid having to sell the flywheel i have and buy another...
Old Dec 8, 2007 | 06:55 AM
coinage's Avatar
anyone have any input?
Old Dec 8, 2007 | 08:16 AM
Kevlo911's Avatar
Kevlo for President
No it uses a different timing ring so it has a different signal. You need to use the maxima timing ring...
Old Dec 9, 2007 | 01:55 PM
Merlyn's Avatar
And... I'm out
Call up Fidanza themselves, tell them you received a 350z flywheel and ship it off to them.
I have a LIGHTENED Flywheel from Fidanza and when I received it I called Fidanza up and sent them pictures of my flywheel and they asked me to ship it to them and they would ship it back fixed, cost me nothing...
With these pictures they could tell it would NOT work on my Maxima
It did cost me shipping.
Attached Thumbnails Requesting picture of VQ35 6sp fidanza flywheel-fidanza1.jpeg   Requesting picture of VQ35 6sp fidanza flywheel-fidanza.jpeg
mclasser
22
Nov 12, 2020 01:58 PM
bigfrank
Oct 1, 2015 12:51 PM
