2002 maxima vibration
Old Nov 6, 2007 | 11:43 AM
2k2maxima's Avatar
Hey guys,
Been having problems with my car shaking a lot. Got it balanced a couple times and aligned. Its a lot better than before but still shakes from 65-75..and then fine again after. I got new rims a couple of months back..and just realized..the mechanic who installed the rims took off this gray portion that sits on the front end of the rotor..here is a pic:
He took that dark grey cover off w/ a flathead screwdriver cuz he told me the rims wouldnt fit. I didnt think anything of it..but now im tryna think..would that cause any shaking ..not having it on?
If I get wheel spacers would that fix the shaking?
Thanks.
*Everytime I get the wheels balanced...the shops tell me they are fine.
EDIT - he took them off only from the rear.
pic courtesy of nicoclub.
Old Nov 6, 2007 | 01:02 PM
oldngivout's Avatar
Willing to learn
The missing dust cap is not contributing to your vibration, but it will allow dirt & water to enter the rear wheel bearings.
And we all know how fragile they are.........lots of people have had to replace them already.
Old Nov 6, 2007 | 01:05 PM
soundmike's Avatar
Very sound, Mike
Are you still using the same tires from before? It could be out of whack internally.
Old Nov 6, 2007 | 02:42 PM
toastedoats's Avatar
find a place that does roadforce balancing and have that done. It may be a tire issue that will only be seen under roadforce
Old Nov 6, 2007 | 05:49 PM
2k2maxima's Avatar
Thanks for the quick reply guys...Yea I had a problem with my stock GLE rims..they were bent up thats why I had to switch my rims. I have not changed my tires from the old rims...so the tires could be messed up?
thanks.
Old Nov 7, 2007 | 04:12 AM
soundmike's Avatar
Very sound, Mike
It's possible, but as Toastedoats mentioned try to have it RF balanced first, that will tell you for sure if it's the tire or something else.
I had a similar issue before, eventually found out it was the steel belts in one of my tires that was causing it. Odd thing was there were no visual indications that would give it away, most belt issues tend to show up as bubbles.
Old Nov 7, 2007 | 04:22 AM
nsnrider's Avatar
did you try rotating your tires?
Old Nov 7, 2007 | 05:24 AM
Prophecy99's Avatar
I had the same problem fitting aftermarket wheels, BUT I didnt have to remove the cover, hence I just dented the cover in to allow the wheel to fit on there without removing the cover.
Did you inspect your aftermarket wheels fully? Maybe you have a slight bend that is only felt on the highway? (dont forget the inside lip you never see)
Old Nov 7, 2007 | 06:45 PM
2k2maxima's Avatar
yea..i buaght them new..the old rims were all whacked out..so im assuming they had worn out my tires unevenly which is why im experiencing the shaking from 65-75. Im using the same tires as before...i cant seem to fidn a spot around my area that uses the hunter roadforce balancing machine. the only places seems are dealerships...
thanks.
Old Nov 7, 2007 | 06:51 PM
irish44j's Avatar
retired moderator
tires could be out of round
tires could be cupped due to poor alignment
could have bad wheel bearings
could have worn/bad tie rod ends
could have worn/bad lower balljoints
could have worn/bad strut
could be bent driveaxles
There are alot of things that could cause vibration. The first thing you need to do is a full visual inspection of the wheel/suspension assemblies to make sure everything is bolted down, and looks as it should. Also you need to determine where the shaking is comign from - front? rear?
Old Nov 8, 2007 | 04:50 AM
soundmike's Avatar
Very sound, Mike
thanks.
Try this link.
Old Nov 9, 2007 | 07:59 AM
antonello104's Avatar
...NYG...
I also have a shaking around 65-70 and then it stops. also how can i check if the wheel bearings are bad ? please help
Old Nov 16, 2007 | 09:26 PM
Scottwax's Avatar
That's Mr. Detail to you
Check the wheel balance first, that is usually the cause.
Nintensity
Aug 13, 2015 05:41 PM
fastcarny
Aug 12, 2015 03:50 PM
papo99
Aug 9, 2015 07:24 AM
yat70458
Aug 3, 2015 01:16 PM
