2000 SE versus GXE manual shift
Old Nov 16, 2007 | 12:45 AM
  #41
bonzelite's Avatar
Originally Posted by Scottwax
Wish I had that kind of time, but I don't. My old car was totaled about 3 weeks ago and the rental bill was rising.
Plus, we had a ton of rain this summer which really hurt my detailing business. Now that it is finally dry, I am absolutely swamped with work...which is good but leaves me with very little free time.
I understand. Feast or famine. I'm self-employed, too.
Old Nov 16, 2007 | 12:46 AM
  #42
bonzelite's Avatar
Originally Posted by NmexMAX
Don't tell me you don't need ANY more detailed info, because, YES, I can provide yes, I can........'
Ok, sure, bring it; I'd like to see it. If you have a cross-section of many year makes that would be super genius of you
Old Nov 16, 2007 | 01:16 AM
  #43
NmexMAX's Avatar
dot dot dot ...
Ok, show me the delta of your DRF's.
Old Nov 16, 2007 | 02:00 AM
  #44
bonzelite's Avatar
You are an engineer or computer analyst? You want a rate of change in Depth Resolution Functions (DRF)??
"the deconvolution of SIMS profiles analysed at very low primary energy (0.5 keV/O2+) is addressed. The depth resolution function (DRF) of the SIMS analysis in presence of roughness is established and a deconvolution procedure is implemented without or in presence of roughness on samples containing delta-doped layers of boron in silicon. It is shown that the deconvolution procedure can lead to a great improvement of the full width at half maximum (FWHM) of the measured peaks in the case where no roughness in detected in the crater bottom. In the case where it is present, the conditions required to use a deconvolution procedure are discussed, and the deconvolution is implemented using precise and restrictive assumptions."
regardless of your jargon, you want a rate of change of something....ie, "Delta" is from physics, for example, the difference between the actual change rate and the target change rate.... something like that?
Old Nov 16, 2007 | 06:20 AM
  #45
Scottwax's Avatar
That's Mr. Detail to you
Regardless of transmission though, my Maxima is waaaaaay quicker than my 170 hp V6 626 was.
Old Nov 16, 2007 | 10:14 AM
  #46
bonzelite's Avatar
Absolutely. I have a VG 3rd gen, 5spd. It was 160HP stock. I've modified it and it maybe --maybe-- makes 180HP. The 2000 5th gen already exceeds that in stock form, so for me it's fast enough. I'm more into modding it's suspension than trying to get it faster with engine bolt-ons.
However I am soon changing the clutch to Exedy Stg 1, and flywheel to Fidanza. So I'm half-lying And I may swap out the y-pipe and exhaust, but with something quieter. Not a Magnaflow. Those are nice but too loud in the cabin.
I want to maintain the sleeper/boring look of the exterior, though. Like grandma drives it.
Old Nov 16, 2007 | 11:34 AM
  #47
MaxBoost925's Avatar
Drug Money
My 2000 makes 250hp to the crank. However it's about to be 450+hp to the crank.
I got what you have and more obviously.
IIRC, my friend's stock 2001 dynoed at 178whp.
Old Nov 16, 2007 | 11:49 AM
  #48
bonzelite's Avatar
Indeed, that's pretty bad a$$ to have that HP on a Maxima. You could stop at 250 and that would be plenty for the street. But I know very well that it's never enough...
What are you doing to have the driveline handle that power?
That sounds about right.
Old Nov 16, 2007 | 11:50 AM
  #49
A33 VQ30DEK's Avatar
you got a spare motor for that thing.. with the miles on your car... i don't think you should be boosting to much..
Old Nov 16, 2007 | 12:00 PM
  #50
Drug Money
No biggie man, they lots of VQ35DE and lots of 4G VQ30DE at Venus Auto and Japan Engines.
And plus, Matthel went through like what? 6-7 engines?
Old Nov 16, 2007 | 12:32 PM
  #51
NmexMAX's Avatar
dot dot dot ...
@ my drunk postings.
Old Nov 16, 2007 | 12:35 PM
  #52
Drug Money
O rly? That explains a bit.
Old Nov 16, 2007 | 12:40 PM
  #53
SoonerFan's Avatar
Cletus
thats why i ordered this little kit
Old Nov 16, 2007 | 12:41 PM
  #54
NmexMAX's Avatar
dot dot dot ...
It was obvious.
Old Nov 16, 2007 | 12:42 PM
  #55
Drug Money
beotch please!
  #56
NmexMAX's Avatar
dot dot dot ...
What's the CR on those and how are the RB's?
Old Nov 16, 2007 | 12:44 PM
  #57
Drug Money
I'm assuming Jason will run high compression since he's gonna stay N/A....... right?
Old Nov 16, 2007 | 12:47 PM
  #58
SoonerFan's Avatar
Cletus
* Compression Ratio: 9.0:1
* Bore: 95.7mm (OEM 95.5mm)
* Displacement: 3513cc (OEM 3498cc)
Old Nov 16, 2007 | 01:10 PM
  #59
Drug Money
You serious? you're running lower compression for the benefit of larger displacement. 87 octane FTW?
Old Nov 16, 2007 | 01:12 PM
  #60
SoonerFan's Avatar
Cletus
thats not what i ordered...i just posted the specs of the first one i found on google. didnt even check the specs.
10.6
Old Nov 16, 2007 | 01:29 PM
  #61
NmexMAX's Avatar
dot dot dot ...
Ok, so what is the bore then?
Old Nov 16, 2007 | 01:34 PM
  #62
SoonerFan's Avatar
Cletus
Bore 95.50
Old Nov 16, 2007 | 01:40 PM
  #63
Drug Money
Bore 95.50
how long till you come back?
I'm gonna go to your house and eat all your food.
Old Nov 16, 2007 | 01:41 PM
  #64
NmexMAX's Avatar
dot dot dot ...
Bore 95.50
I'm guessing a touch more dome than stock (10.3 vs 10.6)?
Old Nov 16, 2007 | 01:46 PM
  #65
SoonerFan's Avatar
Cletus
early july for good...i will be back for three weeks in feb
Old Nov 16, 2007 | 02:01 PM
  #66
antonello104's Avatar
...NYG...
Not to sound foolish but is there a bolt on kit for the 2003 ? i have looked everywere and can't find anything. The only thin i can come up with is greddy's kit for the altama, but you need to get costom down pipes? any answers ?
Old Nov 16, 2007 | 02:12 PM
  #67
NmexMAX's Avatar
dot dot dot ...
are you talking about?
Old Nov 16, 2007 | 02:14 PM
  #68
Drug Money
woo. hahaha
that was definitely the est post of this thread.
Old Nov 16, 2007 | 02:16 PM
  #69
NmexMAX's Avatar
dot dot dot ...
And it did have its share of competition.
Old Nov 16, 2007 | 02:23 PM
  #70
Drug Money
indeed.
Old Nov 16, 2007 | 06:06 PM
  #71
ummmm
Old Nov 16, 2007 | 06:11 PM
  #72
Stardust's Avatar
F---ing Kangaroos
What kind of CAI should I get? Injen or Berk?
Old Nov 16, 2007 | 06:42 PM
  #73
SoonerFan's Avatar
Cletus
one of each...mAd tIgHt cOlD aIr sUcKiNg yO
Mar 12, 2020 12:06 AM
Socalstillen
Sep 20, 2015 11:46 PM
2kmaximel
Sep 16, 2015 03:19 PM
ballerchris510
Sep 11, 2015 05:29 PM
