What is the band on the OEM DR2 bulb for?
Old Nov 24, 2007 | 07:28 PM
soundmike's Avatar
Very sound, Mike
I've noticed my OEM bulbs have the band on them, but most photos of aftermarket bulbs don't have them. What is it for, and is it necessary?
Thanks.
OEM, c/o Akinaboy auctions.
Aftermarket, c/o JD Lighting a.k.a Automax95
Old Nov 24, 2007 | 07:40 PM
MetaOrbit's Avatar
Got Projectors?
It's kinda of like a built-in shield.
D2R bulbs are for reflectors. The "shield" on the OEM bulb blocks some light in a reflector application to reduce some glare.
The aftermarket bulbs are really just D2S capsules that have the bases formed such that they can be placed in D2R or D2S housings. They're often referred to by the aftermarket as "D2C"
Personally, I'd spring for a set of OEM bulbs myself. Arc placement is usually better and their lifespan is usually better as well.
Old Nov 24, 2007 | 07:50 PM
soundmike's Avatar
Very sound, Mike
Ah, Thanks, J.
I also just noticed, with the light's on, the bottom part of the reflector doesn't really reflect much light compared to the top half. Have you noticed that on your I at all?
Old Nov 24, 2007 | 08:02 PM
lowincash's Avatar
No More Maxipad
all OEM reflector hid setup are like that. the bottom half don't have much light down there that way light don't bounce off and cause more glare.
oh as for the oem bulbs with the shield...it's to block glare and make the cutoff more uniform when used in the oem reflector. i modified a pair of d2r bulbs (no shield) to use in my oem reflector housing and the cutoff was horrible. there was light shooting all over the place and the output was very crappy. it looked like i had an aftermarket hid kit on haha
Old Nov 24, 2007 | 08:27 PM
00MaxSE's Avatar
Pointy Elbows
Yeah it's weird how the majority of the aftermarket "D2R" bulbs don't have the shields on them.
I have a pair of OEM for sale w/ the shield removed if anyone is interested.
Old Nov 26, 2007 | 09:59 AM
MetaOrbit's Avatar
Got Projectors?
Originally Posted by soundmike
Ah, Thanks, J.
Yep, my I35 (before I retro'd TSX projectors) was like that. It's pretty much like lowincash stated - most OEM reflector setups are that way. Light hitting the bottom of the reflector bounces up and out of the headlight, creating glare above the cutoff.
Old Nov 26, 2007 | 12:42 PM
kzoosho's Avatar
Most after market are d2c is why. They have both cuts for d2r and d2s.
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
