Looking for steel wheels in junkyard for winter tires
Old Nov 27, 2007 | 01:44 PM
monty31's Avatar
I am going to hit up a few junkyards to find a cheap set of steel wheels that I can mount my winter tires on. My question is, what other cars are condidates in terms of offset and lug pattern that can be used on the maxima. I assume I can use 94+ wheels from other maximas. What about other makes?
Old Nov 27, 2007 | 01:54 PM
00SEMAX19's Avatar
Most all 94+ wheels should work fine for you as long as they are 15" or bigger. As for other companies honda, toyota, lexus, ford mustangs and maby others like taurus, mitsubishi, and I believe kia's and hyundi. All should have the same bolt patterns as long as they are the 5 lug versions. I'm not so sure about any of there offsets and center hub bore though. I'm sure others will imput also.
Discount tire and Tirerack.com sell universal 5 lug wheels that work for pretty cheap new.
Old Nov 27, 2007 | 02:17 PM
Maxgig's Avatar
another option is the Mazda3 wheel. I have a book at home that I can pm you with more options if you like.
Old Nov 27, 2007 | 02:32 PM
monty31's Avatar
I'm more concerned if the offset will work because 5x114.3 is a fairly common offset.
Old Nov 27, 2007 | 02:54 PM
bert's Avatar
The thing that I would worry about with junkyard rims is what if one (or more) of them are crooked / dented? Sometimes a rim is crooked / dented and it gives bad shakes at speed.
Old Nov 27, 2007 | 03:39 PM
00SEMAX19's Avatar
5x114.3 is = to 5x4.5 and is not a offset it is a bolt pattern.
Most wrecking yards will put wheels on a balancer and spin them to check for major runout or bends. I've purchased many used wheels from wrecking yards for customers and have never had problems.
Old Nov 27, 2007 | 03:58 PM
MerlotMax's Avatar
Try some 16" wheels from a Altima
Old Nov 27, 2007 | 05:09 PM
SoonerFan's Avatar
Cletus
There’s a More Appropriate Forum for this Question
Dear monty31,
Thank you for visiting Maxima.org! Your stay here will be longer, more productive and infinitely more enjoyable for all involved if you direct your questions to the appropriate part of The Org!
While your question is, indeed, vaguely related to 5th Gen Maximas, it more specifically relates to Wheels and Tires. You are likely to get better, more specific help there.
Oh, and have I mentioned, search first, post second!
Thank you! Come again!
Old Nov 27, 2007 | 06:41 PM
vq35's Avatar
i got the stock 00 gxe wheels..with 90%thread on all 4...no curbage on rims...i want $150 ...pic is on my thread in the vehicles for sale on my max....
Old Nov 27, 2007 | 08:16 PM
monty31's Avatar
Ooops, I meant bolt pattern being common as compared to offset.
Old Nov 27, 2007 | 08:33 PM
irish44j's Avatar
retired moderator
I don't know about that. The 17x6.5 wheels on our Mazda3 have an offset around 50....they would be WAAYYY in there...
They probably fit (I haven't tried) but would not be a very good setup IMO.
Old Nov 27, 2007 | 08:35 PM
irish44j's Avatar
retired moderator
This thread will get play in here for 24 hours before it moves to wheels and tires forum.
thanks,
management.
Old Nov 27, 2007 | 08:43 PM
00SEMAX19's Avatar
I was thinking the same thing, Acura and honda wheels may have the same problem. I think this is only a problem on all the newer model stuff though but not sure
Old Nov 27, 2007 | 08:54 PM
irish44j's Avatar
retired moderator
all I know is that I did try one of my 17x8 35offset track wheels on the mazda and they stuck out of the wheelwells big time
Ideally, it should be pretty easy to find some 4th gen steelies or 5th gen 16s for winter use.
another alternative are the g35 17s, which can be found really cheap on the G forums and are strong. That's what I use in the winter.
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
