Climate Control Light
Old Nov 29, 2007 | 03:47 AM
zachary1988's Avatar
I have a 2002 Maxima with the automatic climate control and the back lights of the "air recirculation" and the "manual air flow control" buttons are not working. I noticed this last night after turning on the lights. The other four buttons are lit up. How can I change the bulbs(if there are bulbs) behind these buttons. Thanks in advance, Ed.
Old Nov 29, 2007 | 04:26 AM
IHAVEA2KMAXIMA's Avatar
LOL! Same thing happened to me... They cheaped out on that one bulb or what?
Old Nov 29, 2007 | 06:54 AM
jasonmax's Avatar
I think it's a design problem maybe
Mine are dark too
Old Nov 29, 2007 | 07:40 AM
jadedmatt's Avatar
there are 4 lights that come on and off when they choose, the EXT light, then the same air recirc and the fan control. i know the bulbs work, because i have seen them all on but they take a rest or something sometimes.
Old Nov 29, 2007 | 07:43 AM
bigjoe87865's Avatar
there was a thread on the org on how to replace the bulbs... i cant find it ... nor do i remember what words i put in the search..... but its there... with pictures...
Old Nov 29, 2007 | 08:46 AM
SoonerFan's Avatar
Cletus
very common problem that most of us just deal with
Old Nov 29, 2007 | 09:24 AM
jasonmax's Avatar
I will take them out and check. I also going to fix the bose HU for the second time...sign..
Old Dec 7, 2007 | 09:46 PM
I got the lights behind the two bottons to work tonight by tapping with my knuckles under the bottons. There must be a loose connection.
Old Dec 9, 2007 | 09:42 PM
MG-SVT's Avatar
It is buried in either the 5th Gen FAQ topic or the Installation Instructions topic (both stickied). I'm too lazy to search but at least that gives you some direction.
My bulbs flickered in and out for a number of months but they are both burnt out completely now -- or loose connection that finally gave up. So I can see the display fine but have to hunt-by-touch for the buttons at night. Haven't fixed it yet.
Old Dec 9, 2007 | 09:54 PM
AceofSpds's Avatar
wat
Have fun fixing it, although my car has manual climate control, i imagine the way the bulbs are mounted in the board is the same. I went ahead and pulled out the bulbs and put in LEDs in their place.
Old Dec 9, 2007 | 09:56 PM
SlurpeeKing's Avatar
mind tellin us how and waht bulbs you used?
how hard is this to do?
Old Dec 9, 2007 | 09:59 PM
lowincash's Avatar
No More Maxipad
mine was out for like 6 months until one time i hit a huge pothole with a loud bang and then after that i noticed my lights were back on o_O
Old Dec 9, 2007 | 10:39 PM
AceofSpds's Avatar
wat
generic LED's that are already wired w/ a resistor in them.
Bascially its not that hard, just very time consuming.
-Get the climate control unit out of the car.
-Take it apart.
-Keep taking it apart.
-Everything comes apart, trust me.
-then when you are down to the board where the lights are, they are just "screwed" in, unscrew them.
-Fasten your led, however you want (i used superglue)
-make a hole for your wires to exit
-re assemble
-hook wires up to a 12v power source, i used the shifter light
-put the climate control back in the console
(these are the most vauge instructions i can give but they are pretty much all you need)
Old Dec 10, 2007 | 06:35 AM
ChevelleRH's Avatar
Yep... same problem, mine chooses when to work, and now I noticed my defrost no longer works... expecting to dig through the FSM for a long time to figure it out
Old Dec 10, 2007 | 06:50 AM
upstatemax's Avatar
Go to the dealer (Nissan or Infiniti) tell them what bulbs you need. Once you have them, pull out the CC unit (similar to pulling the HU), IIRC the back unscrews to give you access to the circuit board and you will see the back of the bulbs. They just twist out and twist a new one back in.
Put everything back and they are fixed, took me 15 minutes and cost me less than $15 to replace all of them.
Old Dec 10, 2007 | 10:56 AM
carsarecool's Avatar
+1 on this same problem, I'm gonna say connection issues as well. Usually my AMB and fan control lights are out til i noticed the other day the AMB and fan was back on but the middle two were out now.
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
asianstyle
Aug 24, 2015 08:29 PM
