Door Alignment
Old Dec 1, 2007 | 06:30 PM
tucker's Avatar
Door Alignment
I have a problem with my front driver's side door. it opens and closes fine, but when it closes, there's a "ka-thunk" sound, with the 'ka' being the unknown noise. The door seems to be just out of alignment, with it being narrow at the top and wide at the bottom. it seems to be hitting something around the middle area of the door. is there any way of re-adjusting the door alignment?
Old Dec 1, 2007 | 08:23 PM
spdfreak's Avatar
My drivers door has a similar problem. After some analyzing it seems as if the plastic/rubber bushing has cracked, leaving the door looking like it's sagging.
You may have a similar issue.
Old Dec 1, 2007 | 09:48 PM
nexus_7's Avatar
it could also be the hinge pin. They can wear out.
Old Dec 1, 2007 | 10:40 PM
JonBlz's Avatar
a.k.a. STuNtMAN
change both hinges my pops had the same problem when he told me about i went to the dealer and bought it nd changed it and the door would close so smooth now then i spray painted the hinges so it can match the car.
Old Dec 2, 2007 | 01:48 PM
spdfreak's Avatar
How much was the cost for the parts?
Old Dec 2, 2007 | 02:20 PM
JonBlz's Avatar
a.k.a. STuNtMAN
ill call the dealer and findout for u buddy adn ill let u know sounds good
Old Dec 2, 2007 | 02:28 PM
'02_EMILBUS's Avatar
hinges wore out, non-coincidentally its the drivers door!
Just get new ones from Nissan; install! And adjust striker bolt maybe!
I had my old man paint mine to match as well, as I was doing other things that needed painting too.
Old Dec 2, 2007 | 03:20 PM
kukx30de's Avatar
I have the same door sagging problem
Does anyone have a write up?
Old Dec 2, 2007 | 04:19 PM
spdfreak's Avatar
Your calling for me? That would be unnecessary, but appreciated.
Old Dec 2, 2007 | 04:23 PM
spdfreak's Avatar
Who needs a write up?
Should be common sence.
I never did the hinge swap, but I would assume it would be something like this.
Put a block or two under the door to support it, covered with a towel (so you don't scratch the paint) and unbolt the hinges.
Replace with the new ones.
Thats all.
Old Dec 2, 2007 | 07:41 PM
Thats all.
it is common senSe*
be sure to tape the seam between fender and door w/ masking tape to prevent nicking!
Old Dec 2, 2007 | 08:07 PM
spdfreak's Avatar
Originally Posted by '02_EMILBUS
it is common senSe*
Yes, dont forget that too. Have someone hold the door.
Old Dec 3, 2007 | 04:58 AM
buellfire's Avatar
I just bought a 2001 I30 w/ a 152k on it. Mine does the same thing. Thanks for the info. Are the Maxima hinges the same as the I30's? The Nissan dealer is right up the street, and the Infinity dealer is all the way across town.
Old Dec 3, 2007 | 08:43 AM
AnDyMaN's Avatar
i would recommend getting a second hand as it would really suck if something happened and the door fell over. you just like standing rims up... happen to me twice, never again.
but you might just wanna try adjusting the bolts on the hinge and see if you can do any kind of adjusting. but the first thing you gotta do is remove the fender. i believe its about 1 bolt behind the headlight, 3 along the engine bay, and 1 or underneath the car. then, it should be easy adjusting from there.
as far as pricing goes, i believe that is somewhere around 20-30 for each hinge.
Old Dec 3, 2007 | 09:53 AM
kukx30de's Avatar
Thanks for the input sir.
I was exactly thinking about this i.e. fender coming in the way and the possible paint nicks while getting the hinges off.
Definately more work involved than just common sense LOL.
Old Dec 3, 2007 | 02:00 PM
There's no need to remove the fender, thats just more work. You have to take it off, put it back on and align all your seams????
Use a jack to hold the door, AFTER taping the seams. Have someone hold the door while you unplug wires and remove hinges.
Reverse this for installation. Little adjustments will probably need made to get the door fitting correctly.
Old Dec 3, 2007 | 08:12 PM
cefiro80's Avatar
This procedure isnt really that hard. Just replace the hinges it is a lot easier than it seems. ALl the info you need is in this thread already.
Old Dec 3, 2007 | 11:07 PM
spdfreak's Avatar
If you want to take a look at the parts, get the FSM from phatg20.net.
Old Dec 4, 2007 | 10:42 AM
Old Dec 5, 2007 | 01:39 PM
tucker's Avatar
Thanks all for the input! didnt realize it was that simple to readjust/replace the hinges
Old Dec 12, 2007 | 12:27 AM
tintin's Avatar
Every one have the same problem. And me too, also the driver's side
Old Dec 15, 2007 | 11:21 AM
Flyer88's Avatar
Seems a bit ridiculous, but I feel it coming on with my 02 too, with just 104,000 KM
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
