high pitched whining noise from engine
Old Dec 14, 2007 | 09:38 PM
SlurpeeKing's Avatar
hello everyone
i need some help
my 02 max is making some weird high pitched from the engine everytime i accelerate
it sort of sounds like a turbo spooling,
it only happens when i accelerate, as soon as my foot is off the gas, the noise disappears
any ideas?
thanks in advance
Old Dec 15, 2007 | 05:57 AM
nismomaxct's Avatar
No idea what it is, but I have the same problem. Its not crazy loud, byt it used to only happen between 35 to 40 mph, but now I hear it all the time it seems. Its the strangest thing.
Old Dec 15, 2007 | 07:14 AM
Scottwax's Avatar
That's Mr. Detail to you
Vacuum leak perhaps?
My car makes a faint 'chirp' sound at 900 rpm as it revs up or down, but only at 900 rpm.
Old Dec 15, 2007 | 08:38 AM
metalpiotr's Avatar
03 Maxima, 6spd
alternator maybe? often before the alternator goes, it starts making a high pitched whining noise that increases with the revs.
when I heard it on the 95 max I used to have, the alternator went the next day.
Old Dec 15, 2007 | 08:41 AM
metalpiotr's Avatar
03 Maxima, 6spd
hmm.... I get that on my 03 as well. you think that's a vacuum leak?
Old Dec 15, 2007 | 09:15 AM
Scottwax's Avatar
I doubt it, my idle is very smooth and it is only as it passes through 900 rpm up or down, no other rpm at all.
Old Dec 15, 2007 | 07:28 PM
RodzMax2002's Avatar
Mine does that too even from a light roll from 30MPH, it does sound like a turbo spooling up.
Old Dec 15, 2007 | 09:19 PM
SinGin's Avatar
__________________
My 03' Auto does the same thing. Its the front engine mount, behind the radiator with the wire coming out of it.
Old Dec 15, 2007 | 09:33 PM
Drockb418's Avatar
maybe the transmission? my friends bmw does that noise (well did he did a 5 speed swap)
Old Dec 15, 2007 | 09:53 PM
Scottwax's Avatar
__________________
So it is normal then?
Old Dec 15, 2007 | 11:22 PM
SixSpeedSwen's Avatar
This girl drives stick!
does it happen in a certain RPM range? Could possibly be your timing chain hitting the cover... I get a strange noise, kinda like a metal rattle noise when accelerating but also disappears once I let off the gas... mine began after a horrible experience at Jiffy Lube and took months of "we cannot duplicate the problem" responses from the dealer... finally took it to an infinity dealer and after an oil consumption test I found out it is my tensioner which needs oil pressure to work properly and keep the chain tight... apparently its a common issue in the 3.5L's in both the max and the infinity.... good luck.. it's annoying!
Old Dec 16, 2007 | 06:57 AM
Scottwax's Avatar
Just curious, what did they do to fix it?
Old Dec 16, 2007 | 08:28 AM
I'm not that knowledgeable of the "mechanics" of my car so I'm not going to event attempt at getting into detail... I know if involved taking alot of things apart because they were trying to avoid it for a while... in the end they had to replace the tensioner (it was bent)... i'm sorry i cannot tell you how much it cost because the owners of the infinity dealer are family friends and refused to let me pay for it. But since then, no issues.
Old Dec 16, 2007 | 09:18 AM
thats exactly what it sounds like
i know that the noise is coming from the engine, no transmission, no wheels, etc
but cant put my finger as to where
Old Dec 16, 2007 | 09:25 AM
datdude20's Avatar
4 some reson mines did it when i put my intake on.....i later found out that the clamp holding the filter came loose and it was squeezing air through the tiny gap that was between the pipe and filter...
Old Dec 16, 2007 | 09:45 AM
merlin2375's Avatar
could be a vac leak like mentioned above but this it sounds like it could also be an issue with belts.
Old Dec 16, 2007 | 10:33 AM
nlmaxima's Avatar
How old are your belts and how many miles?
Old Dec 16, 2007 | 10:37 AM
dineth00i30's Avatar
as someone already mentioned it could be your alternatoer three weeks ago my i30 made a high whining noise when i accelerate and and few hours later my car just stopped in the modile of the road because the battery died and i had to get a new alternator.
p.s. my car made a loud high pitch noise when start it cold and after new alternator it dusnt
Old Dec 16, 2007 | 03:55 PM
i now have a SES so im bringing it in tomm after my exams to check it out
i do need new belts, car has 73k on it now
Old Dec 16, 2007 | 05:35 PM
Scottwax's Avatar
No worries about the cost, just wondering if simply replacing the tensioner fixed it or maybe it was an oil pump or main bearings causing low oil pressure to the tensioner that was the real cause.
Old Dec 16, 2007 | 09:16 PM
nope... unfortunately the real cause was a Jiffy Lube "oil change" that apparently never happened, because when i went back to the dealer after supposed oil change ... there was virtually no oil in it and still had a Nissan oil filter in there! first and last time i ever took the max there!
Old Dec 16, 2007 | 09:23 PM
Divewjason's Avatar
Someone's going to be in trouble!
Old Dec 16, 2007 | 10:52 PM
VQHP's Avatar
Sunglasses required..
I don't know
Old Dec 18, 2007 | 06:01 AM
phatboislim's Avatar
anyone with this same sound also have issues with power lost in there 3.0s?? i'm looking at a 2000 SE, possibly picking it up this week and i hear this same noise, and it seems like the engine is lazy. my gsr that was stolen two months ago felt quicker than this by a long shot and i thought the maximas were suppose to be on the same 'playing field', if you will with the DC2s..
anyone care to impart some knowledge?
Old Dec 18, 2007 | 06:02 AM
mystican's Avatar
check your belts and the idler pulley...sounds exactly like the turbo spooling...
Old Dec 18, 2007 | 06:21 AM
u mean whether the belts have tension or the condition of the belts?? and to check the idler pulley i'd have to pull of the timing chain cover?
Maxima.KsA
May 15, 2020 04:14 PM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
dcardello
Sep 3, 2015 11:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
