CAI install HELP!
Old Oct 25, 2001 | 06:24 PM
theMax's Avatar
CAI install HELP!
on a 2001.
I can't get the fuse box to fit back. Do you leave the white bottom portion of the fuse box on?
Maybe my hole is in the wrong place? Is the hole centered between the battery tray bolts? or is it closer to one or the other? It clears the battery but that damn fuse box!
Help!
Old Oct 25, 2001 | 06:31 PM
BigDogJonx's Avatar
Re: CAI install HELP!
Originally posted by theMax
on a 2001.
Help!
How much you get this PR CAI for? I hear it makes you lose alot of low end but gives you a major increase in the high end?
Old Oct 25, 2001 | 06:36 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Did you put the template on correctly? The reinstall is a tight fit, but it does fit.
Old Oct 25, 2001 | 06:54 PM
theMax's Avatar
I had a faxed template and had to resize it. I think its a little off. Any tips Kev? Nice new sig.
So you did get the white bottom of the fuse box cover back on right?
BigDogJonx:
It does not give me any Hp right now cause i cant get it installed. www.Cattman.com has them for $200.
Old Oct 25, 2001 | 07:04 PM
theMax's Avatar
Re: ??
Attached is the template I used. I resized to get the correct spacing between the battery bolt holes (7.25").
Old Oct 25, 2001 | 07:08 PM
Y2KevSE's Avatar
Re: ??
BigDogJonx:
Hmmmmm..... does the rest of the stuff fit correctly? Are you done with the install (minus the reinstallation of the fuse box)?
Thanks for the compliment.
Old Oct 25, 2001 | 07:13 PM
theMax's Avatar
Re: Re: ??
Everything else is good. I haven't put the battery back either.
I just cant get the fuse box to fit with the bottom part attached. I really don't want to leave the wires exposed underneath.
You don't happen to have a pic of the hole do you??
Old Oct 25, 2001 | 07:19 PM
Y2KevSE's Avatar
Hmmmmmm..... is there a writeup in the How-to thread? Pioneer posted a step-by-step. Now that I think about it, my wires were exposed.
Old Oct 25, 2001 | 07:27 PM
theMax's Avatar
Yep, must have missed that. Pioneer said to discard the white plastic. I hope the wires are ok exposed like that.
thanks, time to reinstall
Old Oct 25, 2001 | 09:46 PM
Y2KevSE's Avatar
Put weather stripping in between so the wires and tube won't get damaged.
Old Oct 25, 2001 | 10:10 PM
Dustyroads's Avatar
Put the weather stripping where?? I haven't re-installed the CAI because winter is coming, but I'm still trying to figure out how to get it to not rub against the hole and make that terrible scratching noise. I figured it out because part of the paint was worn away on the pipe itself. Do you wrap the pipe with the weather stripping?? Just wondering. Thanks Kev!!
Old Oct 25, 2001 | 10:13 PM
Y2KevSE's Avatar
Nah, just a big enough piece to cover the area where the wires rub against the tube.
Old Oct 25, 2001 | 10:30 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: Re: CAI install HELP!
From what I've read a CAI is the best for both. You don't lose as much torque on the low-end as a POP and you get a big increase in horsepower on the high-end with a better sounding growl(no whistle ).
The theory of how it works seems to support this.
Dixit,
If I were you I would get a Cattman Y-pipe($tealin sucks *****) and then a PR CAI, especially if your worried about the waranty.
Old Oct 26, 2001 | 08:59 AM
theMax's Avatar
thanks all!
It's in, finally!...but I have a little squeaking when I accelerate from a slow speed. I think it is were the hole and pipe meet. Well off to add more weather stripping.
Also as noted in another thread, my filter touches the fender cover you remove to get the filter in.
Overall I wish it fit a little better but it sure is tight where the battery and fuse box meet.
Old Oct 26, 2001 | 10:05 AM
Y2KevSE's Avatar
The piping will rub in a couple spots... fuse wires and hole.
Old Oct 26, 2001 | 11:26 AM
MrBurner's Avatar
my piping doesn't rub by the hole because they give you that long piece of black rubber to line the hole with and w/ the black plastic, its a perfect fit
Old Oct 26, 2001 | 12:01 PM
Y2KevSE's Avatar
The piping will rub the plastic piece which will produce funny noises when accelerating from a stop. I wasn't thinking metal to metal.
Old Oct 26, 2001 | 12:04 PM
PIONEER's Avatar
My Filter rests on the plastic fender lineing. Hey It Don't want to cut that thing out. Rains a lot here, Don't want to get water and dirt in that thing. Mine does make noise at low RPMs.
Kevin, thanks for pointing the Post out. That's why its there. To help Folks out. Brian from Cattman told me he was gonna start putting that thread with his CAI's document when he ships em. Not sure of that though.
Old Oct 26, 2001 | 12:09 PM
Y2KevSE's Avatar
No problem, Ali. Your write-up is excellent.
Old Oct 26, 2001 | 12:43 PM
matt calder's Avatar
brown nose.....
Ali what have you been up to...
Old Oct 26, 2001 | 12:51 PM
PIONEER's Avatar
Originally posted by matt calder
brown nose.....
Matt, what's up man. Yo, There's a Supra/Celica meet at Pinehurst 2nd week of november. My Supra should be ready to rock by then. I'm going. If you come along I'll take the MAX.. See If Brian wants to come along.
Old Oct 26, 2001 | 12:57 PM
Ohhh that sounds like fun, I think i might have to come up for that. I have to ask off first. So it will be on the Nov 9 or so. I will give brian a call this weekend.
Hey I am pretty sure I am going to state next year, so that will be pretty cool. Definately have to hang out, and get a good rematch going again.
Old Oct 26, 2001 | 01:14 PM
Y2KevSE's Avatar
brown nose.....
Shut your hole, stick boy.
Old Oct 26, 2001 | 01:36 PM
PIONEER's Avatar
I'll let you konw for sure.
State is 5min from my house. I'll race you on 540. You can play Catchup
Old Oct 26, 2001 | 01:52 PM
Y2KevSE's Avatar
OoOOOOOOoooOoOooooo........ he's calling you out stickboy.
Old Oct 26, 2001 | 02:06 PM
Nice, sounds good to me.......Dont let that last little race we had get your hopes up Ali, you are going down, Representin' the 4th gens baby....
Shaddup keving, i aint scared...
Old Oct 26, 2001 | 03:11 PM
PIONEER's Avatar
Matt, U betta grab on to your panties boy. I've got more power then you think
Old Oct 26, 2001 | 07:15 PM
theMax's Avatar
damaged filter?
Have you checked your filter where it rests? I bought my CAI used and the filter has a hole in it (metal wire worn off) where it must have rubbed. Looks like I'll have to get a new filter. I put a ton of weatherstrip on it for now.
I eliminated the noise at low RPM's by putting weather striping on the pipe where it meets the battery and fuse box.
I still wish it did not touch the fender
BTW, nice writeup, without your page I would still be trying to fit the white part of the fuse box on top of the pipe.
Old Oct 26, 2001 | 08:03 PM
PIONEER's Avatar
Re: damaged filter?
Oh, I have cleaned it a few times. Its the rubber that makes contact with the plastic first so I'm not worried about it damaging the filter. But the noise it makes is annoying. It sounds like the front of my car is streching or falling apart.
Old Oct 27, 2001 | 10:07 AM
hehe, unless you have one something else to your car since the last time I saw you, then be prepared to lose...
Old Oct 27, 2001 | 01:49 PM
SFMax20SE's Avatar
You guys pretty much answered all the questions... but here is my experience with the Cattman CAI:
Very tight fit.
Fuse box will not fit back with the white bottom piece on. I used weather stripping and flex tubing to protect the wires.
It makes a funny rubbing noise when starting from a full stop or changing directions. It whistles at partial throttle.
But well worth it!
Old Nov 12, 2001 | 04:26 PM
MaxTuner's Avatar
Very tight fit.
But well worth it!
Does anyone know where to put the AEM by pass valve on CAI?? Before the MAF or after the MAF?
Old Nov 12, 2001 | 05:36 PM
BigDogJonx's Avatar
After it, meaning right before the cone filter. Not on the small pipe that is going to the engine. Got it?
Cause you dont want it before the MAF cause then if water ever did in there there, you would get it all over the MAF sensor.
Dixit
Old Nov 13, 2001 | 01:02 AM
Maximum Velocity's Avatar
Very tight fit.
But well worth it!
Since the Cattman CAI pretty much the same as the PR one, does the PR one give the same problems?
Old Nov 13, 2001 | 07:23 PM
theMax's Avatar
same
cattman sells the PRCAI. They buy the metal parts from PR and sell them. They include their own rubber sleeves.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
A32goldylocks
Sep 16, 2015 01:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
