Window Issue
Old Dec 30, 2007 | 10:09 AM
Professor's Avatar
Window Issue
So i replaced the right rear window motor because it went down and never came back up, well i installed the new motor, same thing.......wtf, i swapped switches to no avail, i checked relays, fuses nothing is outa wack, i can manually put the window up with a battery and wires right to the motor..... but it just wont work like its ment to, any ideas ?
Old Dec 30, 2007 | 10:10 AM
joshz's Avatar
Hova
have you checked the track? maybe there's something blocking it?
Old Dec 30, 2007 | 10:11 AM
Professor's Avatar
its a new track and motor, if i hook power up to the motor it work smoothly both ways.
Old Dec 30, 2007 | 05:45 PM
Professor's Avatar
SIGH
Old Dec 30, 2007 | 06:18 PM
SoonerFan's Avatar
Cletus
are ALL the switches good?
all the other switches work in a relay with the switches on the driver's door. if the driver's switch for that window isnt working, the switch on that window wont work.
Old Dec 31, 2007 | 09:01 AM
Professor's Avatar
Yeah, they all work, its odd, it will go down but not up.......iam gona recheck the switches, i did the LED mod to the switches, there is a small possibility that i messed something up
Old Jan 1, 2008 | 08:56 PM
zero2sixtyZ's Avatar
You embarrass me.
check the contacts inside the switch. my friend lost a few of them and i had to replace the switch to get it to work.
Old Jan 1, 2008 | 09:59 PM
Professor's Avatar
ive done that, it still wont work ><
Old Jan 1, 2008 | 10:20 PM
spdfreak's Avatar
Wire torn inside the plastic coating?
Mar 12, 2020 12:06 AM
The Frye
Feb 3, 2019 08:34 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
