optimal exhaust inlet size for 2k1max
hello again kev
i was originally gonna go all out with performance mods but do to lack in funds and reassesment of priorities i think i'm just gonna get an exhaust. I already have the intake.......i guess that would be considered as basic mods. Could you explain why you suggest 2.25 for basic and 2.5 for heavy?
Thanks again
Thanks again
HKS Exhaust and R/T Cat combo..
If I couple the R/T cat convertor with the HKS Exhaust would that be considerd a stupid thing to do becasue I don't have a full cat back like the Greddy Evo?
Basically, I;m asking if it's pointless to get the R/T cat if I won't have a full catback like the Greddy.
Re: Re: HKS Exhaust and R/T Cat combo..
Originally posted by yo_its_ok
Perfectly fine...when you have the car on the lift.... you'll see the two crimps aroound the factory resonator, and want a 2.25" mid pipe made or 2.5"
-Peace
-Peace
Re: Re: optimal exhaust inlet size for 2k1max
2.25 for basic mods... 2.5 for heavy mods
if I got a 2.5" anyway?
Backpressure
Backpressure helping on an NA motor is a myth. Not trying to flame. Less backpressure is always better, the determining factor of whether you lose torque is exhaust velocity. In order for the exhaust to leave the cylinder as quickly as possible is for there to be less pressure in the exhaust pipe. This is created by high exhaust velocity, the exhaust gases leaving the engine quickly. The best way to get most power is to have less back pressure, WITH high exhaust velocty, a really big diameter pipe decreases backpressure but the exhaust leaves the cylinder quickly but doesnt move as fast through the piping. 2.5inch is optimal for our engines, make sure its mandrel bent though, mandrel bends increase exhaust velocity.
Oh bah...so be it....
Remember this is just if I change the MUFFLER only.
Dixit
Re: Backpressure
*edit* I spelled "pulses" wrong.. forgot the first "s"
Re: Re: Backpressure
Originally posted by got rice?
You are overlooking the exhaust pules and the overlapping of the valves to help low end grunt. If you have no backpressure you will not be able to utilize the overlap and low end torque will suffer. Yes, less backpressure is 'better' for race applications where the vehicle is at higher rpms but for street use you have to find the fine balance between the two.
Okay.......I have a JWT popcharger and I'm planning on getting the
R/T Car convertor and the HKS exhaust. How will this combination affect my low end and high end torque?
Re: Re: Re: Backpressure
Re: Backpressure
Originally posted by AznWontonboy
so why doesnt anyone just run with no exhaust piping at all whatso ever? just put headers, and everything else, screw it.. Think man think.
you will have no low-end.... it will be LOUD.... and it will be quite illegal
knight_yyz
Nov 1, 2015 01:34 PM
