Got 2 codes...unhappy with my car.
P0462 - Fuel Level Sensor Circuit Low Input
P0507 - Idle Speed Control System RPM Higher Than Expected
Don't know what either means or how to fix it. My car has been slowly draining me of money since I bought it.
Car has 104,000KM (60,000MI). Spark plugs were changed 3 weeks ago, and a cracked rear valve cover was replaced 2 weeks ago. All service was done by one of the most reputable Nissan techs in the area. Last week my car threw those codes at me, had em both cleared by partsource and it was fine for a week until today when it came back on with those codes. Any ideas what to do?
I think since you just had service done and the codes happend after the service I would just take it back as you are doing.
Sorry can't be more help.
Here is an answer...
I had the fuel level sensor at about 65KKm, replaced the sensor under (extended) warranty. It's accessible by the top of the tank and you get there by removing the rear seat IIRC.
If that is the cause make sure they do a Idle air relearn for you at no cost after fixing the leak.
No leak thankfully, but it needed an idle relearn which I performed today.
I believe the fuel sensor code was caused when I almost ran my car dry(couldn't find a shell!).
I'm unhappy with the car because since I bought it in March 07 I've had to replace a wheel bearing and hub, airbag sensor, DRL module, Bose, Ignition coil, Rear valve cover and a few other items. Yes the spark plugs are basic maintenance, but the rear valve cover cracking?? I don't think so. I maintain my car extremely well, using only high end products...I just want it to run problem free for a few months, is that too much to ask? As of this very moment, it is running perfect so we'll see how long that lasts.
Much thanks to all who helped me out!
P0507 Problem
OK. After taking my 2k3 in for plug replacement, I also got the P0507 problem. While doing the plugs, the shop cleaned the TB too. P0507 pops up. After searching, I reset the codes and ran through the three procedures in the FSM (IAVL being the last). My RPMs dropped from 1100 to 600. Like other people have seen on the next restart, the idle goes back high to 1100 rpm and P0507 fired.
Now it is back at the shop. I was told that they changed the TB but it didn't help. They are currently looking for a vacuum leak. Hopefully they find one. If they don't, should I recommend a ECM reprogram or replacement? Would this help if the IAVL only works until the car is restarted?
Any other ideas on how to fix this problem? I'm not clear if the unplugging of the MAF before the IAVL helps, as mentioned in a previous thread.
I have 82k so I'm not covered under any warranty.
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
I'll have to ask the shop what exactly they did to clean the TB. Assuming the TB cleaning is the problem, what would fix the P0507 code?
I was told they tried to replace the TB and that didn't work.
after replacing the new TB you have to relearn it again.
Everytime you guys replace your plugs DO NOT dissconnect TB electrical connector just set it aside or else you may have to do an IAVL.
IAVL should clear the idle speed. However we've seen some TBodies blow after cleanings and not wanting to complete the relearn.
Regarding your other code i don't know if you can just replace the sensor only or the whole fuel pump assy. But yank the seat out and it's underneath it and depending on if the sensor comes by itself or not it is very straightforward. Just don't smoke or use electrical impacting drills (they spark) on them screws and you should be fine.
Also order the o ring (gasket) for fuel pump.
If you want just do the whole pump if you have higher milage that way you don't have to worry about it and it even comes with a new in tank filter
my car never pops a code, and I can't find any difference after performing ecu reset and idle relearn procedures.
My car has a slight rough idle b/c I can see the tachometer moves up and down a little.
My P0507 Code Fixed
In case anyone has the same P0507 problem, here is my info.
I got my spark plugs changed and the shop also cleaned the TB in the process. Since that time, I have had a P0507 idle too high code that won't clear. Things that were tried:
1. reset ECU codes
2. replaced PCV
3. replaced TB
4. IAVL procedure every time the car is started (for a month). The procedure where you press the gas pedal five times, etc. did fix the problem until the car is restarted.
I paid $105 to the dealer and they fixed it by doing their idle volume air relearn procedure and the problem appears to be fixed. The service guy said that they use a $5000 console that is only available to Nissan service centers and that they needed to pull the fuel injectors during the procedure(?). He said nothing about an ECU re-program. The bottom line is that I was not able to fix the problem without taking it to the dealership since they have the special console to reset the idle speed.
1. reset ECU codes
2. replaced PCV
3. replaced TB
Sbg....did you tell the dealer the TB was messed with? I have the same problem. Tried all the resets and all, and no luck. I'm going to bring it in to the dealer, should i let them figure it out or tell them straight up i messed with the TB? Anyone have a preference with koeppel or Star Nissan in NY. thanks
If it IS under warranty, I would keep my mouth shut.
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
