My new 1/4 times
Old Oct 27, 2001 | 02:50 AM
maxracer27's Avatar
My new 1/4 times
As some of you would remember I was the one that broke my car after I ran it the first time. I ran 15.363 @ 89mph on that very first run.
I went to the track again last night to see if I would do better. I did, this time I ran 15.236 @ 89.59mph. On my second run I did 15.527 @ 88.45mph. I missed a shift on my second run. I shifted to 3rd instead of 2nd. I'm still not used to shifting with the gated shifter.
1st run:
R/T ..... .633
60' ..... 2.316
330 ..... 6.452
1/8 ..... 9.841 @ 73.40 mph
1000..... 12.747
1/4 ..... 15.236 @ 89.59 mph
2nd run:
R/T ..... 1.031
60' ..... 2.380
330 ..... 6.606
1/8 ..... 10.059 @ 72.25 mph
1000..... 13.004
1/4 ..... 15.527 @ 88.45 mph
2K2 Maxima SE
3700 miles
Old Oct 27, 2001 | 06:46 AM
UMD_MaxSE's Avatar
Got Bent?
not bad
Get those 60 ft times down and you will easily be running 15 flat probably. How are you launching?
Old Oct 27, 2001 | 07:12 AM
amsa's Avatar
Re: My new 1/4 times
What about 0-60 times? How would you compare the 2002 Auto Max vs the 2002 Altima 3.5 SE. I have no idea how quick the auto Altima is, I can't find specs anywhere.
Old Oct 27, 2001 | 12:12 PM
adman's Avatar
Wow...that's better than SCCA Solo2 does in his fully modified Honduh CRX!!!
Congrats
ADMAN
Old Oct 27, 2001 | 01:38 PM
maxracer27's Avatar
Originally posted by UMD_MaxSE
not bad
I'm launching at almost idle...... too much rpm and I just smoke my tires throughout 1st gear.
Old Oct 27, 2001 | 01:56 PM
UMD_MaxSE's Avatar
Got Bent?
Your is an auto right? Try flashing the TC. Hold in the brake hard. Mash the gas pedal and then let go of the brake a split second later. That should give you a nice launch.
Old Oct 27, 2001 | 09:26 PM
ChillWill2000's Avatar
Wow thats great!!! sounds to me like 14's are right around the corner!!!!!
Old Oct 27, 2001 | 11:19 PM
kit99bar's Avatar
seems like a stock 2002 max auto
has a strong bottom end and comparisonwise a weak top end..
tip to get a ypipe to free up that hi rpm power
Old Oct 27, 2001 | 11:27 PM
AznWontonboy's Avatar
get a stillen intake, lose some on the bottom (which is good for your situation, spinning through first) and gain some on top.. I think this mod would be nice with the Y pipe.
Old Oct 28, 2001 | 05:52 AM
UMD_MaxSE's Avatar
Got Bent?
no y-pipe for the 2k2 yet
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
