Buying a maxima.. how to test for oil leaks
Old Jan 24, 2008 | 10:23 AM
z28dreams's Avatar
So,
I'm looking at a few Maximas this week. Reliability seems pretty good, but I'd like to avoid any with the dreaded oil leak / ring problem.
Is there a good way to identify a vehicle that has this problem? Or will I simply have to have a leak-down test done on the car?
If so, how much would a mechanic charge for a leak-down test and what would it cost?
Anything else I should watch out for? (I'm looking at 02-03's)
Thanks!
Old Jan 24, 2008 | 12:33 PM
K20z1_rsx's Avatar
Check for a leaky power steering hose. It is the pressure line that is metal-to-rubber (like A/C lines) between the passenger strut and firewall. The rubber part of the line has a thick foam isulation around the rubber push or pull it down it expose the rubber hose. If flesh fluid can be seen on the hose or soaked in the foam insulation it needs replacement. The hose cost about $180 + 2-3 hours labor.
Mine started to leak about a month after I bought it. It is 2003 Maxima w/84,000 miles.
Old Feb 8, 2008 | 09:07 AM
lenwood's Avatar
I just bought a 2003 SE this past Saturday. I just took it to the dealer to have a spare key made, and they found an oil leak at the oil cooler on the bottom of the block (where the oil filter attaches). They told me that its not as simple as changing a gasket, they'd have to replace the entire cooler. That sounds like a load to me, but I'll look into it further this weekend.
Thanks,
Chris
Old Feb 10, 2008 | 12:08 AM
SWerVeDriVeR's Avatar
lenwood, let me know how it goes. I think I have the same problem on my '02 SE w/ manual trans after replacing the oil pan gasket 3x.
Old Feb 10, 2008 | 12:47 AM
AceofSpds's Avatar
wat
Just like any car, check the exhaust tips, run your finger along it and check to see if there is an oily residue.
Old Feb 10, 2008 | 06:44 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
get under the car and looks for shinny places... see some ..there a chance there was an oil leak... power steering pump and brake booster
Old Feb 11, 2008 | 08:08 PM
aventerav's Avatar
I've had a power steering link for a while, I've been putting off getting it fixed.
kjlouis
Oct 3, 2015 05:29 AM
Maxima30
Sep 7, 2015 06:13 PM
DrVee
Sep 4, 2015 12:18 PM
crazyespn
Sep 3, 2015 01:30 PM
sdotcarter
Sep 2, 2015 09:53 PM
