Messed up Tranny... again!
Old Jan 30, 2008 | 07:09 PM
Insane Maxima's Avatar
All right ... so i have got a 2k max and i have already replaced the automatic transmission once. Granted, i put a junkyard transmission in it the last time, but still... are the 2k auto tranny's that bad? I really dont drive my car that hard for the tranny to blow up again.
Has anyone else had this problem? Is there a place where i can get a either new or rebuilt transmission for cheap? Thanks guys.
Old Jan 30, 2008 | 07:19 PM
pmohr's Avatar
No more Maximas...
They're only as good as the maintenance they recieve, for the most part.
What happened to it this time?
Old Jan 30, 2008 | 07:35 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I know and everybody knows that Maxima Auto tranny sucks.. but two... already... damn!!!!!
Old Jan 30, 2008 | 07:36 PM
pmohr's Avatar
No more Maximas...
Jime went 12.4 on a stock trans
I'm on my 4th, right now
Old Jan 30, 2008 | 07:38 PM
MaxFanatik's Avatar
my last 99 max had lmsot 200k on the car/trans... never had an issue with it. It was best tranny i had.
Old Jan 30, 2008 | 07:43 PM
F***ed up Tranny!
well the first one got messed up becasue the previous owner had flushed the transmission like 6 or 7 times before i got it. What i did with this one since it was a junkyard tranny was added a transmission oil cooler. May or may not have been a mistake idk. but what its doing now is freaking out and slippin between second and third about 5 or 6 hundred rpm, and then between second and third only about 3 hundred. So im obviously getting a little aggrivated. im jusdt going to spring for a new or rebuilt one depending on the price. Any suggestions?
Old Jan 30, 2008 | 07:49 PM
pmohr's Avatar
No more Maximas...
5/6 hundred RPM? Or 5/6 thousand RPM?
Trans cooler shouldn't pose a problem.
New is ~$3k, rebuilts are hit and miss depending on what shop does it.
Old Jan 30, 2008 | 07:55 PM
ya my bad.. 5 to 6 thousand ... any other suggestions? $3 k is kinda out of my price range
Old Jan 30, 2008 | 08:00 PM
pmohr's Avatar
No more Maximas...
Junkyard trans. Once again, hit or miss, but that's pretty much all ya got at this point.
Old Jan 30, 2008 | 08:02 PM
DrunkieTheBear's Avatar
Turbo'd Saab
just manual swap it like I'm going to
I'm at 140K miles its running amsoil syn and a tranny cooler.
its slipping a little but not much, I grind on it hard at autoX
but this summer its gone.
Old Jan 30, 2008 | 08:18 PM
Grand_hustle17's Avatar
CAR-PARTS.COM
Old Jan 30, 2008 | 08:22 PM
mines do the same, it will drag out first to second then a hard shift, i am planning to 5spd mines too
Old Jan 30, 2008 | 08:40 PM
Drockb418's Avatar
is there any kind of write up about the swap?
Old Jan 30, 2008 | 08:41 PM
Scottwax's Avatar
That's Mr. Detail to you
Shift manually for now, it increases line pressure and it shouldn't slip as much.
I second the motion to just get another transmission out of a wrecking yard, try to find one with as low mileage as possible and run a carfax on the car it came out of. Make sure you drop the pan and inspect for metal shavings, clutch material, etc and the fluid smells like ATF is supposed to smell like.
Old Jan 31, 2008 | 05:14 AM
unfortunately ive already been through the process of inspecting the magnets. Its not a good sighn. Ive been interested in doing the 5-speed swap for a while now. Any kind of instructions for the linkage and everything else? Been looking for a totaled maxima for a while that i can just swap everything out of.
Old Feb 1, 2008 | 08:36 PM
Any other ideas guys? Really trying to get my car up and running again. Got a beat a** 89 honda prelude si for the time being and its killing me not to be running the max!!!
Old Feb 2, 2008 | 03:29 PM
Merlyn's Avatar
And... I'm out
Either buy yourself a new transmission from Dave B (Don't say that is overboard, because I did it, and I am 20, and yes I paid for it), or 2. Shop around, it is really a personal choice which shops to go to etc. I personally just got done rebuilding my transmission, so technically I am on my 3rd... and I have an 02...
Old Feb 2, 2008 | 03:53 PM
tsaulz's Avatar
Pick up a low mileage junkyard 6spd and do the swap. Aside from the occasional bad 3rd gear synchros, the 6spd should hold up much better than another 4AT or 5MT. No input shaft bearing issues, stronger gears, and way better gas mileage to boot.
Old Feb 4, 2008 | 11:31 AM
SSandMaxima's Avatar
Slipping between 5-6k rpm? Hmm...
First, I am an old fart (well... 47, close enough). I have had absolutely no problems with my transmission so far (108k miles). That said, I've had my engine up to 5-6k rpm maybe three times in 7 years. Which reminds me to a story:
A man went to a doctor, and said, "Doc, it hurts when I do this!". The doctor replied, "Then don't do that."
You push your Max to the max, you pay the price.
Old Feb 4, 2008 | 11:40 AM
pmohr's Avatar
No more Maximas...
Going WOT is hardly 'pushing the Max to the max'. You consider that beating on the car?
Old Feb 4, 2008 | 11:49 AM
CAR-PARTS.COM, some are warranted
Old Feb 4, 2008 | 11:50 AM
1sexyleo
seems like we have the same problem. sometimes my car slips so hard it redlines and bumps off the revv limiter. but only between 2-3.
ima buy another tranny with 20k miles on it for $500
Old Feb 4, 2008 | 12:14 PM
no no it doesnt slip at 5-6k rpm... it slips about 5-6 thousand rpm when it goes to shift. But thats only between second and third. Im confused tho. Generally when the transmission starts to go bad, doesnt it slip going from a stop? My max will stay strong in the gear its just bad when it goes to shift. Is there a ecm flash that would refresh the computer and maybe shift better? Im just hoping and praying that its not the transmission again
Old Feb 4, 2008 | 03:32 PM
Scottwax's Avatar
No, they usually start slipping on shifts first, then the wear and extra heat end up taking out the tranmission over time.
Old Feb 4, 2008 | 06:54 PM
meccanoble's Avatar
Sports Button FTW
Auto trannies...thanks for reminding me why I went 5 speed and if i'm forced to go auto i'm switching to German...
BMW 335i coupe FTW!
Old Feb 5, 2008 | 07:16 AM
Allright... so ive been looking at rebuilding the transmission myself. I found a rebuild kit online for around $500... anyone attempted this? Whats the labor hours like and im sure there are specialty tools needed.. anyone have a list or a place where i can find these things?
Old Feb 7, 2008 | 12:54 PM
bump
Old Feb 7, 2008 | 04:40 PM
Scottwax's Avatar
Have you ever seen the inside of an automatic tranmission? Pretty complex.
This ought to give you an idea: http://auto.howstuffworks.com/automa...ansmission.htm
You *can* rebuild one, but expect it to take several hours and you may need some special tools.
Old Feb 7, 2008 | 05:03 PM
pmohr's Avatar
No more Maximas...
Honestly people tend to think automatics are far more complex than they really are. As long as you have documentation and a relatively clean and unobstructed workspace, someone with automotive experience can bang most rebuilds out in a few hours (plus some time for cleaning parts).
The only real involved parts are ensuring that the gaskets and seals are positioned properly, everything is properly cleaned, and that the VB and checkballs are replaced properly.
Everything else is pretty much snap rings and bolts, remove and replace parts.
Then again, I can see how it would look to someone who's never done a trans before. In my opinion (and experience), it's far easier to rebuild an automatic than it is to rebuild a manual.
Old Feb 7, 2008 | 10:44 PM
Scottwax's Avatar
Rebuilding a .030 over 350 for my Chevelle (took me about 1 1/2 hours to put it together, including plasti-gauging all the clearances) was far less intimidating than rebuilding the TH350, so I just picked one up at a wrecking yard for $100, put in new front and rear seals and a shift kit.
Old Feb 7, 2008 | 11:01 PM
pmohr's Avatar
No more Maximas...
Between a small block and a turbo 350, I'd rather rebuild the trans, 10 out of 10 times. Just my personal preference, though.
Old Feb 8, 2008 | 12:15 AM
AceofSpds's Avatar
wat
Are you people sure its not your solenoids or TCM???
Old Feb 8, 2008 | 07:17 AM
I was hoping and praying that it was the tcm or the solenoids because the labor involved with that would be a lot less time comsuming... but i think that the tranny is slipping wayy to much to just be something electrical
Old Feb 8, 2008 | 05:11 PM
Scottwax's Avatar
I have a feeling our automatics are a lot more complex than a TH350.
Personally, I hate all the electronic controls. So much easier when you could adjust shift feel via the dowshift cable.
Old Feb 11, 2008 | 05:00 PM
bump
Old Feb 11, 2008 | 07:08 PM
cefiro80's Avatar
I would look into a tcm before a tranny. There are threads on what tcm models to get.
Old Feb 16, 2008 | 03:47 PM
Griller07's Avatar
If it was me, i would go with the 6speed manual swap cuz manuals are more fun to drive, and i believe they don't break as easily as automatics, but which ever you do, good luck
Old Feb 16, 2008 | 03:49 PM
Griller07's Avatar
i mean 5speed swap because you have a 2k max
Old Feb 17, 2008 | 12:28 AM
96blkonblkse's Avatar
Yeah my 02 slips about 200-300rpm under partial throttle on the 2-3 shift, under full throttle it will bounce off the rev limiter a few times before it shifts into third. Very annoying. This 02 altima 3.5SE i drove at work, intake, headers, catback, udp, the tranny slipped bad on the 1-2 shift, it was so bad that it would just sit there and bounce off the rev limiter till you let off the throttle at which point it would shift.
Nissans 4spd auto FTL.
litch
123
Jan 4, 2024 07:01 PM
wyobbagy
Jan 3, 2023 12:03 PM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Colossus
Sep 9, 2015 05:46 AM
