trip computer problem...
Old Oct 28, 2001 | 01:00 AM
DTV's Avatar
DTV
Hi all.. I have a 2k2 Maxima, and just installed an aftermarket Head unit. The stock head unit has 4 plugs.. I bought a wiring harness for a 2k1 max and it fit perfectly for 2 of the 4 plugs. The 2 plugs provides all of the functions for the aftermarket HU (speaker, amp, antennae, power, etc.) The aftermarket HU works totally fine with the other 2 plugs not connected to anything. I'm assuming one goes to the changer, and the other goes to the steering wheel controls.. now comes my question
My trip computer controls on the steering wheel will no longer cycle through the modes of the computer. I'm thinking (for some dumb reason), the trip computer controls goes through the stock head unit. Is there anyway I can redo some of the wires out of the 2 plugs that I left unplugged to get my trip computer working again?? I'm thinking if I can connect some of the wires together it would work.. anyone have any ideas/wiring diagrams??
Thanks...
Old Nov 7, 2007 | 09:47 AM
wdautrem's Avatar
I'm having the same issue. Please let me know if you figure this one out.
Old Nov 7, 2007 | 09:53 AM
Iceman420's Avatar
(insert witty one liner)
My understanding is there is a brown wire that needs to be grounded in order for it to work.
I'm sure others will chime in or you could do a search as I'm sure I read it on here.
Edit: I just noticed you brought back a 6 year old thread instead of searching. Please put on your suit...
Old Nov 7, 2007 | 09:56 AM
SoonerFan's Avatar
Cletus
this has been discussed and answered in the audio/electronics forum
Old Nov 7, 2007 | 11:06 AM
Kyle00's Avatar
WSH for teh cup
What a nice guy you are, no flaming.
Old Nov 7, 2007 | 01:02 PM
HotMaxx02's Avatar
That is where i found the same answer myself 6 months ago and it worked for me.
Old Nov 11, 2007 | 10:11 PM
SEmy2K2go's Avatar
Go BUCKS!!!
You can retain the full function of your steering wheel controls & trip computer by doing the following (which is mentioned in the Audio FAQ's)...
"How do I make the steering wheel controls work with an after market head unit?"
This is a two step process. First you have to obtain the PAC-SWI adapter from Crutchfield or some other mobile audio dealer. This will allow you to utilize the radio functions on the steering wheel.
Secondly, to regain use of the trip computer (the one with temp, DTE, MPG, etc.) you have to first locate the small wiring harness you removed from the stock deck, but didn't use in the install of your after market deck. This is a small harness with 4-5 wires in it. One of these wires is brown with a white stripe/marking. This wire must be cut from the harness, the stripped and grounded. I recommend grounding it to the large metal peice below the vents (you can use a small screw or electrical tape), or any other grounding site. This will now give you full use of all steering wheel controls.
jmlee44
Oct 2, 2022 02:13 PM
mclasser
22
Nov 12, 2020 01:58 PM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Andy29
Sep 29, 2015 05:32 AM
