2003 Coolant Air Bleed Screw?
Old Feb 29, 2008 | 01:12 PM
jo8243's Avatar
I have an '03 Maxima and I just changed the coolant. Is there an air bleed screw anywhere that I need to open while refilling? I don't see one and the FSM doesn't mention one. It only mentions the two block drains (which I didn't remove). The Haynes manual mentions one, but it must be for a different year, cause I can't find one. Anyone know?
Old Feb 29, 2008 | 01:20 PM
Colonel's Avatar
Old Fuddy Duddy
I know on the water tree on the 3.0, that screw is a hex key screw on the top.
As for the 3.5, I am not sure.
When I did the coolant on the 3.0 (thrre times now), I have not needed to open that screw. Meaning I opened it and coolant gushed out. Open = a couple turns.
Not sure if this helps really. Drinking lunches for the WIN!
Old Feb 29, 2008 | 01:30 PM
SoonerFan's Avatar
Cletus
leave the radiator cap off as you run the car up to temp. air will escape.
Old Feb 29, 2008 | 01:52 PM
miksen's Avatar
FU, FU, FU, You're Cool..
I have done the same and it works fine this way
Old Feb 29, 2008 | 02:54 PM
jo8243's Avatar
Even if you leave the cap on, if this method would work, wouldn't it just burp the air into the overflow tank? Or is there a reason it wouldn't be able to?
Old Feb 29, 2008 | 03:17 PM
SoonerFan's Avatar
Cletus
if the cap is open, it goes out...not into the overflow tank.
Old Feb 29, 2008 | 04:22 PM
jo8243's Avatar
Ok, but if the cap is on and the air goes into the overflow tank, it is purged from the system just the same, right?
So my question is... why do you need to remove the radiator cap?
Old Mar 1, 2008 | 05:31 PM
jo8243's Avatar
Anyone?
Old Mar 1, 2008 | 05:47 PM
SoonerFan's Avatar
Cletus
either take my advice or dont
Old Mar 1, 2008 | 07:59 PM
AceofSpds's Avatar
wat
yes because overflow tanks are pressurized when....
seriously though
the cap is spring loaded up to a certain temp just like a thermostat.
Old Mar 3, 2008 | 07:54 PM
jo8243's Avatar
This is how to do it.
Whatever..... Don't be so sensitive.
I wasn't saying you were wrong, just wanted to know why. There's nothing wrong with asking why. If that offends you then............... grow a thicker skin.
Anyway, I tried your method. It didn't work. Just taking the cap off wasn't good enough.
To bleed all the air out (the heater core had air in it and I couldn't get heat from my climate control system), I had to take the radiator cap off, run the car up to full operating temp, then take a piece of rubber and hold it over the filler neck to create a seal while an assistant reved up the engine. This forced air into the overflow tank and got it out of the system.
Without the rubber piece, revving the engine up just caused coolant to be expelled along with the air. Then when you went back to idle, air got pulled back in. With the rubber piece, when the motor was revved, air+coolant went into the overflow jug. When the throttle was released, coolant was pulled back into the radiator from the overflow jug.
A 1992 sentra se-r I used to have actually spec'ed this method in its FSM, except instead of a piece of rubber, they said to use a "specially modified radiator cap with the valve held open".
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
sliptap
Sep 30, 2015 05:57 AM
