strange "whine"
Old Mar 20, 2008 | 09:18 AM
MAXIMA_STYLE's Avatar
strange "whine"
ok so i get this weird whining noise kinda, when i am in park an hit the gas pedal about half a second after i touch the pedal theres this quik whine from under the hood and as soon as the car idles back down it does it once more, any ideas?
Old Mar 20, 2008 | 09:47 AM
hybridioN's Avatar
all teh single ladiez
alternator belt?
Old Mar 20, 2008 | 09:52 AM
no, its not that kind of whine...let me rephrase ...more like a slight squeak real quik and then nothing
Old Mar 20, 2008 | 05:30 PM
Psyfa's Avatar
I don't know where that sound comes from exactly...but I do know that happened to my car on two separate occasions...and right after each a coil died...
Old Mar 20, 2008 | 05:54 PM
OC guy's Avatar
2002 maxima se
could be the bad engine mounts or the transmission mount if not those then could be the vaccum leak. i get this too.
Old Mar 20, 2008 | 06:32 PM
SuperStasiu's Avatar
1. Open hood
2. Start Car
3. If no one is around rev the car with your hand assuming its a 01 or 00 or have some one rev the car while its runing
4. Listen and look at were sound is coming from
5. Did you try this at all before starting this thread?
Theres a couple places it can be coming from:
the alternator
power steering pump
ac compressor
vaccum line leak
bad belts
belt tensioner
a dirty throttle body-disassemble intake piping and look at butterfly valve then clean it with a wet rag
Old Mar 20, 2008 | 06:48 PM
mmotown's Avatar
I posted this same Q; in the 6th gen forum. What your problem is your timing chain. In my case Nissan had to replace a sensor and some other part. Trust me it's your timing chain. I can look for my receipt and tell you exactly what it is.
Old Mar 20, 2008 | 11:05 PM
ShIft_uR FacE's Avatar
Have you changed your oil recently by any chance?
Old Mar 21, 2008 | 01:37 PM
well lets see, ive opened the hood and listened i cant quite pinpoint the sound but its near the front of the engine on the pass side, my oil was changed about 1700 miles ago, and i hope to god its not my timing....thats quite costly
Old Mar 21, 2008 | 07:11 PM
Was the whine there before the oil change? What kind of filter did you use? You need to get UNDER the pass side
Old Mar 21, 2008 | 07:26 PM
the whine has been there since i bought the car just didnt really notice it all that much considering i got a 1000 watt amp in the trunk....and it doesnt change when i change my oil, ive used three different filters since i started hearing it...
Old Mar 22, 2008 | 02:04 AM
Hmm. Changed any other fluids?
Old Mar 22, 2008 | 03:56 AM
nope no other fluids changed...it almost sounds like my idler pulley but im not sure
Old Mar 22, 2008 | 12:07 PM
Try turning the wheel and see if it makes the sound change for a second then go back...if so i have the same problem and it very well could be the idler pulley being that the rpm bounces a bit when i turn the wheel.
Old Mar 22, 2008 | 04:32 PM
hanklin00's Avatar
i too have a wineing noise like that hwo much does a idle pully cost to change
Old Mar 22, 2008 | 05:33 PM
turning the wheel does nothing its only when i touch the gas pedal and then let off
Old Mar 22, 2008 | 05:37 PM
SoonerFan's Avatar
Cletus
the timing chain doesnt cause a "whine" it causes a rattle.
please keep your advice to the 6th gen forum
Old Mar 22, 2008 | 05:38 PM
SoonerFan's Avatar
Cletus
that really sounds belt/pulley related
Old Mar 22, 2008 | 05:52 PM
so basically i should start by changing my belt and see if that works??
Old Mar 22, 2008 | 07:22 PM
Well since you posted that you have a 1000 amp im gonna say that its your alternator dieing i've heard this on cars with sound system without really good electrical system for the sound system its just a tiny whine at the start do to the fact that when your car starts the alternator is under load u might look into getting a replacement one ready
Old Mar 22, 2008 | 09:42 PM
Scottwax's Avatar
That's Mr. Detail to you
Let me guess. It makes a soft, quick "chirp" when you lightly rev past 900 rpm and again when it goes back down under 900 rpm? My car does the same thing, someone said it had to do with the motor mounts. 4 months later, no change in the sound, frequency or loudness so I am not going to worry about it.
Old Mar 23, 2008 | 02:36 AM
Psyfa's Avatar
see that's the exact sound I thought he was talking about...except I only heard it when my coils were about to fail. I don't know what the relation is...if there is even a relation but it happened to me twice...so I dunno...get a free scan just in case?
Old Mar 23, 2008 | 07:13 AM
Scottwax's Avatar
Wouldn't hurt to have it checked out.
Old Mar 24, 2008 | 06:00 AM
that is the exact sound i am talking about, and i doubt its my coils because its been doing it for 3 months now with no change at all
Old Mar 26, 2008 | 02:28 AM
riceyasian86's Avatar
Maybe you have a supercharger you don't know about. Hehe.
Old Mar 26, 2008 | 08:56 AM
P. Samson's Avatar
A continuous high pitched "whine" as someone mentioned above can be a precurser to the alternator packing it in. The other thing that can generate a "whine" is an over-tensioned serpentine accessory drive belt, particularly with the Maxi because it is adjustable.......not a spring loaded tensioner. I also have the "chirp" on accel and decel from/to idle, but I don't really know how long I've had it. Doesn't seem to be from the accessory drive end of the engine......I think it may be just the IACV.
Old Mar 26, 2008 | 09:13 AM
Well, its not affecting y performane or anything like that so i not to concerned with it, i was just curious if anyone knew what it was, obviously its something with a maxi, theres numerous people that got the same issue
Old Apr 12, 2008 | 02:45 PM
BabaYaga's Avatar
I have same problem with my Maxima 2000 (78K) and now with Infiniti I35 2002 (47K), the only difference that on Maxima it is much louder and on Inf it is just started and it is not loud yet.
I would like to fix it before I sell the car, but no idea what to fix!
Please, help!
Old Sep 30, 2010 | 10:03 PM
coug95's Avatar
Please, help!
The chirp related to going past 900 RPM's is indeed the electronic motor mounts. The mounts can change the stiffness internally (idle and above-idle conditions). Mine got so bad that they were cycling 6 times everytime I was on and off the throttle. I found a guy that posted pictures on how to disconnect the harnesses and remove this functionality from the electronic motor mounts. I unplugged mine, and have been happy ever since. I cannot tell a difference in the vibrations or performance of the car. I recommend searching for a thread on disabling the motor mounts. I have been happy since I did this. Oh yeah, there is a rumor out there that the mounts can short out the ECU... expensive. Although, I have not heard of this happening yet.
Old Oct 1, 2010 | 01:41 AM
levellkinchen's Avatar
its the electronic motor mounts going bad. simply disconnect them there are some pics on this site somewere.
Old Oct 1, 2010 | 09:53 PM
Scottwax's Avatar
Never did anything to the engine mounts, still no problems more than two years and probably 50k miles later.
Old Oct 1, 2010 | 10:09 PM
Maxterror's Avatar
2 years later
Hondarydr
Dec 30, 2024 06:15 PM
tarun900
19
Dec 20, 2021 06:57 PM
Chebosto
Sep 11, 2002 05:36 AM
Cumalot
Feb 21, 2001 10:01 AM
