Crank pulley Indestructable
Old Mar 24, 2008 | 07:12 AM
Delearious02's Avatar
Ok so I just got my max the other day and the crank pulley broke off i guess the belts were too tight. Anyway after doing research on here and finding a couple write ups this past Saturday i went out and attempted to get my pulley off. ya ok well i completely destroyed 2 craftsmen 19mm sockets and the bolt didn't even budge. You may say well craftsmen suck or something like that but that is just sick. Anyway do you guys think i should just find a impact socket and try to get the crank bolt out that way or just take it to a shop who can use a impact to get it off. I don't know if anyone else has run into this but i was just very surprised about this whole thing figured id share.
Old Mar 24, 2008 | 07:28 AM
Puppetmaster's Avatar
Yes, try a double walled impact socket with an impact or a breaker bar. Did you do the engine blip method or just elbow grease?
Old Mar 24, 2008 | 10:26 AM
Engine Blip
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
yep impact socket is going to be the way to go. Just use it with your breaker bar or if you don't have one, put your regular rachet on it and take a hammer to it for some ghetto impact. It will come lose eventually just like it would with an impact wrench.
Old Mar 24, 2008 | 10:32 AM
!PrjctMax!'s Avatar
That **** works wonders!
OR
Put the wrench on and have a friend hold it in place while you get a big piece of wood and hit it a couple of times...hopefully you two trust each other
Old Mar 24, 2008 | 10:33 AM
Originally Posted by Delearious02
Engine Blip
Cool. Just use an impact socket and you should be all set.
Old Mar 24, 2008 | 10:45 AM
knight_yyz's Avatar
Toolie
don't smash your ratchets with a hammer. get a piece of pipe and insert the ratchet handle in there for more torque...
Old Mar 24, 2008 | 10:53 AM
Matt93SE's Avatar
STFU n00b!
or you could save your tools and use an impact wrench. that's what they're designed for.
Old Mar 24, 2008 | 11:01 AM
SoonerFan's Avatar
Cletus
impact.....
Old Mar 24, 2008 | 06:26 PM
NisTech's Avatar
if it is really tight sometimes a 2135 T.I. even might not get it off (rarely though) If so we use a breaker bar with some pipe on it. And on the pulley itself we wrap a pipe wrench. It's like a long bar with a chain that locks onto the pulley so it won't spin.
And use an impact socket. It's more flexible and won't crack.
Old Mar 24, 2008 | 07:18 PM
irish44j's Avatar
retired moderator
my impact gun has never met a bolt it can't break free
Old Mar 26, 2008 | 10:32 AM
Will give it another try this weekend we shall see what happens
Old Mar 26, 2008 | 09:27 PM
GodFather's Avatar
Made in Taiwan
My mechanics would just torch that pulley for a while, then somehow, use the air impact wrench and easily get the bolt loose.
-Peter-
Old Mar 27, 2008 | 07:55 AM
mowgli29's Avatar
Horizontally opposed.
breaker bar. wedge it between the pulley and the ground. crank the motor for a split second to break it loose. pretty ghetto, but it works for those of us who have air compressors that can't support an impact
TKHanson
Nov 24, 2018 01:39 AM
chisam14
Nov 6, 2018 08:56 PM
zmcneely13
Sep 26, 2015 02:26 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
