Foglight removal...
Old Apr 4, 2008 | 10:09 PM
00MaximaGXE's Avatar
Foglight removal...
Just wondering if I can remove my foglights to replace the bulbs...how would I go about doing this...I have an early gen5, I searched and saw nothing.
Old Apr 4, 2008 | 10:22 PM
AEMAXIMA01's Avatar
well then you didn't search for the right thing.
http://forums.maxima.org/showthread....+removal+light
Old Apr 4, 2008 | 10:32 PM
SoonerFan's Avatar
Cletus
when people start repeat threads with common problems...and try to use this disclaimer...and we know its a lie...we dont appreciate it.
when people spoon feed and give the answer...which makes the behavior seem ok...we dont appreciate it.
Old Apr 5, 2008 | 05:30 AM
You know your an a*hole...I have never been on a forum and met a bigger **** than you...How do you know I didn't search? Where you standing right over my shoulder? Don't accuse me of not searching...Just voicing my opinion, I know you do.
Old Apr 5, 2008 | 06:09 AM
gotendbz1's Avatar
yea soonfag like to tell peopel to search so he can post *****.
Old Apr 5, 2008 | 06:36 AM
mist max2000's Avatar
..the only thing hes saying is that after the same thread every 2 weeks.. fog lights.. exhaust crap.. ''cold air'' intakes..well u get the idea.. it gets kinda annoying when they keep comming up when theres answers everywhere if you use the search...
oh. and id be careful at the language .. you get free vacations for it..
to answer ur ?..
1. jack up front of car
2. remove plastic and other screws that hold the plastic shield on
3. unscrew foglight.. pretty self explanatory when ur looking at it.. G/L
IBTL....
Old Apr 5, 2008 | 07:19 AM
gotendbz1's Avatar
to answer ur ?..
IBTL....
then he should just not post in that thread, if you dont have an answer stfu, y post ***** in other people thread for.
Old Apr 5, 2008 | 12:22 PM
SoonerFan's Avatar
Cletus
the person above found a thread by searching...i just searched and found 15 threads about this.
i dont have to be over your shoulder to know that you DID NOT search.
Old Apr 5, 2008 | 02:50 PM
to keep this site clean of stupid threads that ruin the 5g forums... bottom line...
Old Apr 5, 2008 | 02:54 PM
SoonerFan's Avatar
Cletus
and something simple like this....just start doing it and figure it out for yourself...then you have the satisfaction that you did it yourself
Old Apr 5, 2008 | 02:55 PM
SoonerFan's Avatar
Cletus
im sorry that your feelings are still hurt about the other thread....the one about your rotors being warped...when there was a thread talking about the same thing 5 threads under yours
Old Apr 5, 2008 | 03:14 PM
choiiiiiiiiiii's Avatar
Try proper grammar and English before telling others what to do.
Old Apr 5, 2008 | 09:50 PM
I'm sorry soonerfan but every thread I've been in lately you have been not helping and you just say search. I am on five other forums and a moderator on one and this one by far has been unfriendly to new people. I know how the search feature works, You can tell everyone to use the search feature but the problem is that keywords in the search just bring up unrelated topics. I searched for fog lights, fog lamps, and all is it brought up is what bulb is the best. Not how to specifically remove the lamp itself. Thank you AEMAXIMA01 and mist max2000 The only ones that helped me in this thread.
Old Apr 5, 2008 | 09:55 PM
RacerX1320's Avatar
Sooner wins another fan.
Old Apr 5, 2008 | 09:59 PM
It's not his fault, I know how frustrating it is when new people make a new thread thats been talked about 11ty thousand times, its how he words it to new people that just plain stinks. Makes it sounds like the OP is a piece of garbage.
Old Apr 5, 2008 | 10:23 PM
SoonerFan's Avatar
Cletus
threads on 1st page that prove you wrong
http://forums.maxima.org/showthread.php?t=558596
http://forums.maxima.org/showthread.php?t=558584
http://forums.maxima.org/showthread.php?t=558591
http://forums.maxima.org/showthread.php?t=558535
http://forums.maxima.org/showthread.php?t=556127
http://forums.maxima.org/showthread.php?t=365289 (you should have posted here where im the top poster)
Old Apr 5, 2008 | 11:55 PM
CMax03's Avatar
I hope U got the foglight removed! It's rather easy with the car jacked up, and remove the phillip screw holding the wheel well splash shield to the fascia and 1 snap retainer, then reposition the fwd portion of the wheelwell splash shield out of the way! You'll see the 2 10mm nuts secured to the rear of the foglights, disconnect your foglight harness from the chassis harness, loosen the two 10 mm nuts and push studs fwd! The rest is easy! There should be 3 holes in the foglight mounting area... use a unibit to increase the bore for the foglight beam height adjustment screw! Alot of Maxima foglights are aimed in the dirt!
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
fc95se
Nov 15, 2000 05:14 AM
