noise from front wheel well
Old Apr 11, 2008 | 01:31 PM
gotendbz1's Avatar
i get a metal tapping noise, when i let the car coast, it sounds liek teh noise you hear at the railroad crossing but really low, almost like like a cowbell but real low.. any idea what this could be.
Old Apr 11, 2008 | 02:06 PM
SoonerFan's Avatar
Cletus
year?
wheel bearing
outer CV joint
Old Apr 11, 2008 | 04:35 PM
jasonmax's Avatar
nails in the tyre?
Old Apr 11, 2008 | 05:58 PM
gotendbz1's Avatar
03 max, nah not a nail in tire, the thing is it doesn't happen all the time, but on this one street i go down i can make it happen all the time. The street is a little bit downhill so i can just give it a little gas and coast, and that when i usually hear it. I just remember i recently had my swaybar links replaced could this be it 2? the sound is so low that if i had radio on or windows closed i would hear it at all.
Old Apr 12, 2008 | 12:44 AM
playboi21617's Avatar
Originally Posted by SoonerFan
year?
wheel bearing
outer CV joint
CV joint is the problem. i just mine fixed and it doesnt make the noise and it doesnt make the noise anymore.
Old Apr 12, 2008 | 06:21 AM
gotendbz1's Avatar
ok, after drivign ti todl for a few, the sound is liek when you hit 2 metal pipe agianst each other, i hear it only when i'm around 0-20 mph, it probaly is there at higher speed but with the wind noise i prolly just cant hear it. i don't hear it when going over bumps which is weird, but on road which are smooth but gainy.
Old Apr 12, 2008 | 12:23 PM
SoonerFan's Avatar
Cletus
really....its not that hard to use proper grammar and spelling
its the outer CV joint
Old Apr 12, 2008 | 06:04 PM
gotendbz1's Avatar
are cv and ball joints 1 in the same?
Old Apr 12, 2008 | 06:12 PM
SoonerFan's Avatar
Cletus
http://en.wikipedia.org/wiki/Constant-velocity_joint
Old Apr 12, 2008 | 06:18 PM
gotendbz1's Avatar
was just there, i'm trying to find these online and cant seem to find any. how much do these run for? can i get this replaced for around 150-200 for parts and labor?
Old Apr 12, 2008 | 07:20 PM
SoonerFan's Avatar
Cletus
go to any place that works on CV joints...there are plenty...look in the phone book.
Old Apr 12, 2008 | 07:50 PM
The Hulio's Avatar
motor mount
If it only happens when you're coasting over bumps, check the front lower motor mount.
Joe.
Old Apr 12, 2008 | 11:04 PM
Drockb418's Avatar
sway bar linkage?
Old Apr 12, 2008 | 11:40 PM
SoonerFan's Avatar
Cletus
from the limited information you gave, it could be at least 10 different things....
Old Apr 13, 2008 | 11:49 AM
gotendbz1's Avatar
i had car jacked up and check the 2 front wheels no sound when spinning, so today i'm driving and listening and i think it is the rear driver side wheel, are there, could it be a brake issue.
I can only here it under 20 mph, it could be there when goign faster but with teh wind noise i cant hear anything. it is usually more noticeable when i'm coast at 20 and under, road can be smooth or grainy, i dont get the soudn over bumps.
Old Apr 15, 2008 | 10:13 AM
geenowalker's Avatar
I need more cowbell
Matt93SE
May 24, 2019 02:58 PM
boomerbrian
Nov 8, 2015 05:10 PM
seesole
Aug 26, 2015 11:22 AM
twotonezed
Aug 16, 2015 11:41 AM
BassAddictJ
Aug 4, 2015 11:38 AM
