MMI installed
Old Apr 19, 2008 | 08:11 AM
dizmax96's Avatar
MMI installed
so i got a set of MMI from Taz at racingline. yes they are made for the 6th gen but i said what the hell and gave them a shot. Taz said the front insert will fit, but he wasnt sure about the rear. so i became the test bed.
I have a 6 speed so i can only say how it is for the 6 speeders out there. I opted for these because i didnt want to go thru the hassle of pressing/chiseling out the old rubbers, so MMI's would do. I got a set of street inserts which are well made and tough.
Its easiest to install if you have access to a lift, but it can be done at home if you put your car on jackstand and use the jack to maneuver the center cross beam/motor. i have access to a lift so i used a jackstand on the motor.
Taking the center beam out completely makes the job quite easy as the mounts are connected to the beam itself. the bolts have 17mm heads on them. Center beam is held on by 17mm bolts as well. 4 on the beam 3 for each mount.
Once the mounts are removed the front MMI slips in easily. I opted to mount it on the side with the protruding center bore/hole, which would be the engine side not the transmission side.
Now for the rear. The hole on the rear is centered and the void is smaller than the front. The front has an off center hole and a larger void. I will post pics as well. I used a lot of lube and had to use a screwdriver to pry/pull the insert thru the tight void. Same as the front, i put it on the protruding side. It is quite snug so i know for a fact that the rear wont be moving.
Reinstall in reverse order. Mounts to Engine, center beam to mounts, center beam to subframe. Easiest way is to mount all the bolts by hand than tighten all down. now go for a ride!
If anyone is going to do this, i recommend a harder compound for the front which Taz may be selling for the 5th gen. Which in turn i need to do
All in all not a bad install. its a great alternative to getting ES bushings. here a link to the pics.
When i first installed the front i had put it on the transmission side, then decided it would best fit if the center hole of the MMI were to sit/center of the protruding bore of the engine mount. pics are here
Impressions: Definitely feels great. Less engine movement and great when heel-toeing.
http://s3.photobucket.com/albums/y89/bboydiz/MMI/
Old Apr 19, 2008 | 12:10 PM
SoonerFan's Avatar
Cletus
cool
but that is very hard to read...
Old May 10, 2008 | 06:35 AM
dineth00i30's Avatar
so does your car feel diff now? i want to know before i order mine. thanx
Old May 10, 2008 | 01:51 PM
dizmax96's Avatar
you will feel slight vibration at a stop but other than that its pretty stiff. i recommend gettin the race insert because its stiffer.
Old May 10, 2008 | 04:58 PM
i have an auto. so wouldnt dat mean i have diff resluts.
Old May 11, 2008 | 06:31 AM
dizmax96's Avatar
possibly but the front one is the one that definitely fits for 5th gen. auto should be the same with as manual. but you should check first
Old May 12, 2008 | 07:38 AM
well the manual one also fit the auto but right now im having some problams with my car so i need to get that fixed before any more mods. but thanx for the info.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
