Just confused with these HID's
Old May 14, 2008 | 06:28 PM
SE My 6sp's Avatar
ok i have an 03 max and my passengers side headlight went out, i checked the fuse, and it was ok, i changed the bulb and it still didnt work. So i switched the ballast from the pass side to the drivers side and it didn work so i fugured just the ballast is bad. But when i put the good drivers side ballast on the pass side, it still didnt work So does this mean i have a bad relay or somehing and a bad ballast??? Also i dont have the original headlights i have the factory DEPOT replacement headlights like on Ebay, does anyone know where i can get a replacement from, or should i just cop a $80 ballast from ebay and splice it HELP
Old May 14, 2008 | 07:06 PM
Professor's Avatar
Check to see if there is power at the wires before the ballast, check all under hood fuses and relays
Old May 21, 2008 | 06:14 PM
SE My 6sp's Avatar
i tested the input and there was no power, i believe its the headlight relay, does anyone know where i can get a headlight relay from, besides the dealer, ive been looking all over the net and nuthing
Old May 21, 2008 | 06:54 PM
ZIPPIN's Avatar
Mauja He Mauja
Look in the class section. There are a couple of guys parting out.
Old May 21, 2008 | 06:55 PM
ZIPPIN's Avatar
Mauja He Mauja
Here is one
http://forums.maxima.org/showthread.php?t=561232
Old May 22, 2008 | 01:58 AM
CMax03's Avatar
Look guy you got 4 fuses for your headlights 1 for each HID and 1 for each Hi-beam. You also have 2 headlight relays 1 for each HID! Swap them and see if your problem transfers to the drivers side! Do you have a test light or volt-ohm-meter? if so it's time to pull it out! If swapping the relays doesn't work, test those fuses.......
Miket2006
Mar 1, 2021 03:55 AM
MaxLife17
Jun 27, 2019 01:37 PM
D Mason
Jun 21, 2016 04:43 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
Vistance
Sep 17, 2015 05:17 AM
