Illumina ABS attachment different than stock
Old May 17, 2008 | 03:15 PM
metalpiotr's Avatar
03 Maxima, 6spd
I am installing Illuminas, and just pulled out the 3 break lines from the strut and noticed one of the little brackets for one of the lines on the Illumina strut is much different than the stock one.
The stock one has an open hole (like the other two), while the Illumina strut has a closed in hole. The guys that did the installation, how did you attach the line with the big rubber piece into that one different bracket?
Old May 17, 2008 | 03:30 PM
SoonerFan's Avatar
Cletus
you have to use a ziptie
Old May 17, 2008 | 04:25 PM
metalpiotr's Avatar
03 Maxima, 6spd
Ok. Thanks!
Old May 17, 2008 | 07:19 PM
CMax03's Avatar
Or you can use a nylon clamp size 4 and a thru bolt and it works fine! Some reason or other they designed the ABS like the 4th Gen Maxima!
aw11power
Oct 10, 2021 04:57 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
09maxshawn11
Sep 30, 2015 10:28 AM
jaydot901
Sep 29, 2015 01:18 PM
Noela
Sep 26, 2015 08:22 AM
