right headlight works on and off
Old May 21, 2008 | 06:01 PM
User 12822's Avatar
my high beams work but my right side regular light, or driver's side lamp sometimes works and sometimes doesnt. im pretty sure the bulb is fine, maybe something is loose?
help would be swell
Old May 21, 2008 | 06:58 PM
ZIPPIN's Avatar
Mauja He Mauja
Did you check the wires/plugs? My 00 did that and it was the bulbs. I swaped the bulbs and it worked fine.
Old May 21, 2008 | 11:41 PM
blkAEmax82's Avatar
Glory Glory Man United
Change the bulbs out and worked just fine.
Old May 22, 2008 | 12:04 AM
SoonerFan's Avatar
Cletus
probably a lose filament in the bulb...as others have said, replace it
Old May 22, 2008 | 09:58 PM
babyboyws6's Avatar
get an hid kit from operatic!!! oh yeah!!! that will definitely solve that problem
Old May 23, 2008 | 03:59 AM
sampimpinthug's Avatar
HID's will make it even more worse since they require a lot of power and they are super expensive.
With HIDs there are several things to worry about, the ballast, the bulb, custom wiring. Also HIDs are likely to run out fast and change color.
I would say like others try to replace the bulb if not then check the wirings.
Old May 23, 2008 | 07:30 AM
User 12822's Avatar
alright ill get a new bulb. thanks guys, i just wasnt sure if it would be more a wiring problem or just the bulb.
Old May 23, 2008 | 12:18 PM
Froggmann's Avatar
BTW if you have run higher wattage bulbs in your headlights it's a posibility your plug could be burned. It's happened to a few people i know that put the "Blue" bulbs in their halogen headlights. The fix for this is a new plug, but if you don't feel like doing that you can squeeze the connections together and get a good circut that way.
Old May 23, 2008 | 08:58 PM
babyboyws6's Avatar
our cars are already equipped with hid's though... sooooooooooo ????
Old May 24, 2008 | 12:41 AM
CMax03's Avatar
Where did you learn all that info from? I know HID use less power than Halogen and last longer, but when it breaks it tends to be more expensive to fix! those ballast that Nissan used can be replaced with some of these units found online! Ever removed one? It's a one piece ballast/igniter....but the person with the problem needs to look at his problem a little deeper, it's a easy fix no HID needed!
Old May 24, 2008 | 03:54 AM
mdemonte's Avatar
He probably went to HIDplanet dot com
Old May 24, 2008 | 06:51 AM
User 12822's Avatar
lol no hids, my lights are stock.
Old May 24, 2008 | 03:16 PM
User 12822's Avatar
just for people's knowledge it wasnt the bulb it was the outlet thing that you put the bulb into. i had to bend the bulb metal to stay inside because it kept coming off. the contact was so old and corroded
Old May 24, 2008 | 03:17 PM
User 12822's Avatar
not the 2000/2001s
Old May 24, 2008 | 08:27 PM
babyboyws6's Avatar
Originally Posted by TeH BawNeY
not the 2000/2001s
yeah but hids are cool!! i think everyone without em should goto operatic and buy a kit !!
Maxima_Joe
Nov 25, 2015 08:19 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
asianstyle
Aug 24, 2015 08:29 PM
KristyKarina
Aug 23, 2015 09:53 AM
kenc15
Aug 5, 2015 08:29 AM
