Eibach springs, will my jack fit?
Old 05-31-2008, 03:57 PM
Whitebread's Avatar
Those of you with Eibach springs, do any of you know if a 5 1/2 to 19 inch floor jack will fit under the front and side jacking points? I'm wondering if I will need to return the jack I have and get a low profile one.
Whitebread is offline
Old 05-31-2008, 04:04 PM
Cletus
SoonerFan's Avatar
get a low profile
with H&R and my front lip...i can still get to the front jack point
SoonerFan is offline
Old 05-31-2008, 04:06 PM
Turbo'd Saab
DrunkieTheBear's Avatar
I can still reach mine with the lip and I have the same height for a jack
DrunkieTheBear is offline
Old 05-31-2008, 04:12 PM
Whitebread's Avatar
With a 5&1/2 inch jack you mean?
Old 05-31-2008, 04:13 PM
Whitebread's Avatar
Originally Posted by SoonerFan
get a low profile
[IM]http://i6.photobucket.com/albums/y223/soonerfan1/DSC01335.jpg[/IMG]
Does that one jack up to 19 inches? I had a low profile one before and it was not capable of lifting the car high enough to fit my jack stands. The only low profile jack I've seen that can jack that high is almost 150 dollars.
Old 05-31-2008, 04:28 PM
Cletus
SoonerFan's Avatar
i can get stands under with my craftsman....but it cost around $200
weighs 44 lbs. Lifts from 3-3/4 in. to 18-1/2 in.
Old 05-31-2008, 04:32 PM
Drockb418's Avatar
im dropped on h techs and my jack does fine
if anything use the one that came with your car just to lift it to the point were you jack and ur good to go
here is my jack i like it, its at sams club for 64
http://shop2.aol.ca/shop/product--ca...d_1849385.html
Drockb418 is offline
Old 05-31-2008, 05:13 PM
retired moderator
irish44j's Avatar
1. go out to your car
2. see how much clearance there is for your jack right now
3. if you have more than 1.5" clearance now, then you'll be fine with Eibachs.
irish44j is offline
Old 05-31-2008, 05:35 PM
Whitebread's Avatar
I was going to do that, but it requires me to put the car on a level, hard surface. That means moving the car, and the jack a quarter mile to the street. Posting on the .org was just so much easier.
Old 05-31-2008, 05:51 PM
Cletus
SoonerFan's Avatar
Old 05-31-2008, 06:03 PM
Whitebread's Avatar
Eh, its also dark out. I wont be able to do anything until tomorrow anyway.
Old 05-31-2008, 06:09 PM
retired moderator
irish44j's Avatar
why is your car parked 1/4 mile from a level, hard surface?
or...if you're in a dirt area, just dig away some of the dirt where the jack goes to give yourself clearance.
Either way, this is a really stupid thread.
irish44j is offline
Old 05-31-2008, 06:13 PM
Cletus
SoonerFan's Avatar
+2
Old 05-31-2008, 09:04 PM
4DSCDriver's Avatar
Well, if need be, just keep a couple pieces of 2x10 around in case you need to jack the car up. That would probably give you enought to get the jackl under the car.
4DSCDriver is offline
Old 05-31-2008, 10:16 PM
Whitebread's Avatar
Long gravel driveway in a rural area. I also would not jack a car on a gravel or dirt surface if I can help it. When the car goes up, its done in the garage (which is being cleaned and is in no condition to house a car on jackstands).
Whats the issue? Am I not allowed to ask a simple question? I appreciate whatever help I get, but if its beneath you then you don't have to answer.
Old 05-31-2008, 10:19 PM
Whitebread's Avatar
And do what, drive the car onto the pieces of wood and jack it up from there? I'll do it if I have to but I'd not deal with the band-aid fix. It seems that some have clearance and some don't. I'll take it down to the street tomorrow and measure it.
Old 05-31-2008, 10:40 PM
retired moderator
irish44j's Avatar
Because:
1. Unless we know the exact model of your jack, and someone happens to have one of the same ones, how is anyone supposed to answer?
2. Because peoples cars will sit differently with Eibachs. People use different size wheels/tires and not always in stock diameter spec, so sitting height won't necessarily be the same
3. Because Eibach springs have a 1.5" drop. Your car's stock ground clearance is 5.5 inches, which is generally the rear crossmember. The front lip is probably a couple inches higher (let's say 8"). So take 1.5 from that and you probably have 6.5-7" of clearance up front (even more on side jack points). So if your jack goes down to 5 1/2" you should be fine.
I have 3 different floor jacks and all of them work on my car which has Eibachs PLUS the Mach 1 lip, which hangs down about 3" at the front (they barely clear).
irish44j is offline
Old 06-01-2008, 06:46 AM
Whitebread's Avatar
Because:
1. You don't need the model. A large number of jacks have a capacity on the lower end of 5 and a half inches.
2. Yes after market wheels, tires and tire pressure will effect actual ride height but I have stock wheels with stock size tires and I run tire pressures slightly higher than factory recommended. It's fairly likely that there are other people that have similar setups and can provide at the least, useful estimates. Asking now is prudent because I do not want to put the car up on stands and then be unable to lower it enough with the jack I have. Obviously measuring the clearance on the surface I'm going to jack the car is the be all and end all answer but there is nothing wrong in asking. This is a Maxima oriented discussion forum after all.
3.Eibach's website says the front/rear drop for the 00-03 maximas is 1.3/1.0 inches but that only makes your answer ever more pertinent. That 5 line answer was exactly what I was looking for. And I'm SURE it was easy for you to type. Simple question and simple answer. I'm not asking you or anyone else to do the work for me, I wanted to know from someone who was here before me what worked and what didn't. Real easy answer. I really don't think my threat is so stupid.
Old 06-01-2008, 09:42 AM
trigger005's Avatar
if ur 2 low, u can always use the jack the car came with
thats what i do
trigger005 is offline
Old 06-01-2008, 11:08 AM
03 Maxima, 6spd
metalpiotr's Avatar
I have a cheap MotoMaster one like this:
http://images.canadiantire.ca/media/...0_CC_60a59.jpg
and I have no problem with Eibachs.
metalpiotr is offline
Old 06-01-2008, 12:37 PM
Whitebread's Avatar
thats what i do
Yeah, thats what I think I'll do if I have problems, that is until I get a jack that fits.
Old 06-01-2008, 12:38 PM
Whitebread's Avatar
Whats the lifting range on that thing?
Old 06-02-2008, 06:48 AM
dot dot dot ...
NmexMAX's Avatar
Keep in m ind, if you have to jack your car up in case of a flat, it will be lower. I know this because my jack worked perfectly fine with fully inflated tires. i got a flat, and had to use the POS that came with it because my jack didn't fit under the car when the front tire went flat.
NmexMAX is offline
Old 06-02-2008, 07:58 PM
CMax03's Avatar
I'm using a 3.5 ton Napa floor jack that's 3.5" @ low and lifts car to 21" @ high! My car is lowered and I have plenty of room!
CMax03 is offline
Old 06-03-2008, 09:31 AM
burnurass's Avatar
the craftsman aluminum low profile jack will 100% fit under a progress spring drop maxima even with the stillen classic (02-03) lip. Puppetmaster can verify this..it just fits with very little room to spare but it fits right under the front of the car.
burnurass is offline
Old 06-04-2008, 12:01 AM
CMax03's Avatar
Eibach only lowers the car 1" you have nothing to worry about....
CMax03 is offline
trsandrew
04-08-2016 06:45 PM
JakeOfAllTrades
10-05-2015 10:40 AM
MaxiNoob98
10-02-2015 10:13 PM
followthadollar
09-27-2015 01:06 PM
Pied
09-26-2015 03:29 PM
Quick Reply: Eibach springs, will my jack fit?
