Car wont rev when in gear (03 6MT)
Old Jun 11, 2008 | 04:31 PM
MAXclipse's Avatar
I'll make this short since I pretty much have an idea of what the problem is, just need some assurance.
Last week, was cruising on the highway running around 60 mph when all of a sudden the gas pedal wouldn't "work". Basically felt like I was lifting throttle. I pull over and pop the hood with the car idling, seeing if I could hear anything. Couldn't see/hear anything wrong. Gave it a couple of free revs and it responded, put it in 1st and it drove normally. It has happened a couple of times in the last week (2 or 3 times) but I just would put in neutral, give it a couple of revs (~ 3.5K) and would put it back into gear...no problems. Basically just a bandaid to make it through this work week.
Yesterday, I noticed how slow my windows went up and down and how dim my clock was (lights off, daytime). Did a little research and figure my alternator is ****. Well, I'm driving home today and get about a 1/4 mile from my house and it ****s up again. I pull over to the side of the road, give it some revs and everything looks fine except its having trouble keeping a steady idle and my battery/e brake light come on. So I'm pretty much positive its the alternator. It free revs like a champ, go to put it in gear and throttle just will not respond. This is the only thing that's puzzling to me, but this is my first car with drive by wire so that may be the reason...
Car has about 98K miles on it. TIA.
Old Jun 11, 2008 | 05:28 PM
pmohr's Avatar
No more Maximas...
Replace the alternator (and get the battery checked out, too) then see if it still does it.
Always fix the simple problems (and the ones that have the clearest solution) before attempting to diagnose further.
Old Jun 11, 2008 | 05:43 PM
Lethal's Avatar
I would check the battery first. May as well check the cheaper part first
Old Jun 11, 2008 | 08:50 PM
CMax03's Avatar
I would check both! You could have a bad battery cell as well!
Old Jun 11, 2008 | 10:15 PM
tedo007's Avatar
faster than you think
go to autozone check it out for free
Old Jun 12, 2008 | 12:03 AM
Wise-1's Avatar
To check if it is your alternator, turn the car on and see if the battery is getting charge from the alternator. If not, then thats your problem. (I forget the name of the instrument to check if the battery is getting charge)
Old Jun 12, 2008 | 01:45 AM
majesticmaxima's Avatar
A voltmeter.
Old Jun 12, 2008 | 05:35 PM
nismoedition's Avatar
simple just start the car and take off the terminals and if it dies out its your alternator. And if the throttle is not giving u response try changing the tps 20 dollar part
Old Jun 12, 2008 | 05:36 PM
pmohr's Avatar
No more Maximas...
TPS is a $20 part, hmm? Have you seen the 03 TB?
Old Jun 13, 2008 | 06:20 AM
vinco's Avatar
I believe that if you unhook the battery on a modern Nissan, then it will die whether or not the alternator is good.
Old Jun 13, 2008 | 02:27 PM
Not recommended.
Old Feb 25, 2019 | 01:24 PM
Nic Cushman's Avatar
what could it be if i replaced the alt/battery both please help moms car same prob..
having same problem please help
jaredh5694
Nov 5, 2017 06:23 PM
taz394
May 15, 2010 03:19 PM
Eric F
19
Dec 24, 2009 06:03 PM
mevjen
Oct 11, 2008 07:00 PM
dizmax96
Jun 3, 2005 06:42 PM
