need help installing B.co LTB stg1..few ?'s
Old Jun 26, 2008 | 12:00 PM
mist max2000's Avatar
havnt attempted it yet.. just have a few?'s
1. does anyone know what size the bolt is on the LCA where the tie bar goes into? so i can buy the proper socket..
2. do i need to use an impact gun?
3. does the suspension need to be under a load?
--thanks guys
(going on 026mt if that matters)
Old Jun 26, 2008 | 12:08 PM
trigger005's Avatar
search w/google or somethin
all ur qs have been answered b4
Old Jun 26, 2008 | 02:46 PM
SoonerFan's Avatar
Cletus
i cant remember the exact size...its big
yes,you will need an impact
suspension needs to be under load when you tighten the bolts
Old Jun 26, 2008 | 02:56 PM
wow really.. thanks.. how about i searched for a solid 20 mins because i remember matt writing about stuff and i found josh's write up and read that about his LTB2 install but that didnt answer those ?'s.. thanks though
on a serious note.. thanks sooner.. yeah that thing is big lol .. biggest i had around was 1" and that was too small lol..
Old Jun 27, 2008 | 05:51 PM
irish44j's Avatar
retired moderator
1. IIRC it's a 32mm.....but keep your receipt in case I'm wrong
2. It's never a good idea to tighten bolts with an impact unless you abosolutely can't get it tight enough by hand. That said, I always use my impact on the LTB because it's hard to get alot of force lying under the car with a ratchet.
3. If you have the OEM bushings in there, you need to tighten the bolts with the car on the ground/loaded. If you have poly bushings, you can do it with the car up in the air.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
