Hesitation - I know, please read...
Old Jul 21, 2008 | 09:59 AM
BENMAX03's Avatar
Okay, I have searched all over this forum about this hesitation issue, and I only find on here info on the problem with the manual transmissions. I however have an auto 2k3, and it hesitates under load/hard acceleration. Let me explain, that I have not had this car for the past 8 months, and I'm sure that 87 octane gas has been used most often. Now I have this car back, I've changed plugs, cleaned maf, cleand throttle body, used fuel treatment and nothing but 93 octane or better. Would my hesitation issues be for something the same as the manual transmissions? Like a ecu reflash needed? Anyone else with an auto have this hesitation?
Old Jul 21, 2008 | 10:10 AM
mtrai760's Avatar
'Trynna' is not a word
Could be a MAF going bad.
Old Jul 21, 2008 | 10:31 AM
Kyle00's Avatar
WSH for teh cup
does it only hesitate under hard acceleration?
Old Jul 21, 2008 | 10:37 AM
WhiteMAX02
It could also be attributed to bad precats. They are notorious for failing and that could definatly lead to hesitations when you first accelerate.
Old Jul 21, 2008 | 10:47 AM
BENMAX03's Avatar
I don't know if any of you have done this, but when you use the lower octane gas, it hesitates like that. Like at a full load, when passing on the highway and you floor it, it surges instead of a smooth power curve.
Old Jul 21, 2008 | 11:14 AM
wyche89's Avatar
ECU reflash is only needed when you change something to the best of my knowledge... that 87 octane for the past 8 months could have messed up something in there. If not, then I'm gonna have to go with the official maxima.org diagnosis for 99% of all performance problems: MAF
Old Jul 21, 2008 | 02:18 PM
DrunkieTheBear's Avatar
Turbo'd Saab
there are three things
MAF
precats
drive by wire (electronical throttle)
all very common issues, you could try locating a new maf and see how that works, seeing as how that is the easiest and probably cheapest fix first.
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
trungg86
Sep 4, 2015 04:58 AM
conansriver
Sep 3, 2015 06:38 AM
