Ignition switch bulb replacement
Old Jul 21, 2008 | 11:56 PM
maximo018's Avatar
Could anyone point in the right direction of a thread that has the write up on how to replace 2002 ignition switch bulb or if anyone has the website or write up I would greatly appreciate it.
Old Jul 22, 2008 | 06:29 AM
hi-tek22's Avatar
well i know that the bulb itself is a number 74 bulb that will fit, im not sure about the exact OEM nissan size, but i do know #74 LED's work perfectly
check it:
http://superlumination.com/74.htm
i remember reading the write up myself...but as usual, damn car domain is undergoing some type of maintenance and wont let me in to find the page....
Old Jul 22, 2008 | 07:01 AM
n3985's Avatar
大陆弟弟
Three Philips screws for the cover underneath the steering column, remove those, remove cover. Then it'll be self explanatory, you can just use pliers to take out the old bulb and install new rather than further disassemble.
Old Jul 22, 2008 | 04:10 PM
maximo018's Avatar
Thats what I figured but the 5th gen cover doesn't seem to be a two piece cover like the 4th gen. My only obstacle would be the turn signal & wiper blade switches.
Old Jul 22, 2008 | 04:28 PM
Reizy's Avatar
Check Studman's site for alarm install. He has pictures of trim removal and all. http://maxima.theowensfamily.com/viper791xv/
You might get away with just doing steps 3 and 4. If not, its only 2 screws to take the cover off in step 1. You shouldnt need to do step 2. And while you're in there, put in remote start!
By the way, on my 02 there were only 3 screws holding the steering column pieces together. I guess 5 gen has 4 vs 5.5 gen 3?
Old Jul 22, 2008 | 10:22 PM
maximo018's Avatar
Thanx. And actually I have an 02 I just get lazy sum times & call it 5th gen even though its a 5.5.
kmitchel
Oct 28, 2015 09:46 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
MikesChevelle
Aug 6, 2015 11:36 AM
maxima297
Aug 3, 2015 12:50 PM
