Help Car wont Start
Old Jul 22, 2008 | 05:43 AM
eyecon7's Avatar
Help Car wont Start
Hey guys i went to Start my car today and i cranked it and it immeditaly Shut off... What can be wrong. i have headers on the CAR.. so my o2 are just hanging but even with a bad MAF arent you able to Start it..
Old Jul 22, 2008 | 07:34 AM
eyecon7's Avatar
Bump i pulled Code p1121 ETC ACTR. Something with the Actuator. do I have to replace the throttle body??? I also Pulled P0174 System Lean Bank 2 but thats because of the headers..
Old Jul 22, 2008 | 08:01 AM
JoE'sMaX01's Avatar
Try disconnecting the MAF sensor and cranking the car that would tell your if your MAF sensor is bad. I had a similar problem I would crank the car and it would shut off but only after driving for a while, never happened on a cold start. But that would be my first suggestion to check the MAF.
Goodluck.
Old Jul 22, 2008 | 08:27 AM
Grimsta's Avatar
Ooh, throttle actuator. Yeah, most likely the whole TB. It wont let your car start because it can attain a reading from the throttle and its a safety so it doesnt fire it up at WOT when there's no oil pressure.
Old Jul 22, 2008 | 11:44 AM
cefiro80's Avatar
I would try MAF first no hurt in doing so but my guess is TB as well
Old Jul 22, 2008 | 01:44 PM
SuperStasiu's Avatar
try cleaning out the maf first, then clean out the throttle body. Clean the throttle with a wet rag not by spraying **** in there, just clean the area around the butterfly valve really well
Old Jul 23, 2008 | 04:40 PM
CMax03's Avatar
cleaned that throttlebody recently? forced open that butterfly?
Old Jul 24, 2008 | 08:57 AM
NmexMAX's Avatar
dot dot dot ...
Have you recently done anything to the intake, manifold area? If so, you might want to check fro a vacuum leak.
Old Jul 24, 2008 | 09:56 AM
jasonmax's Avatar
what year of the car?
Old Jul 24, 2008 | 02:34 PM
NmexMAX's Avatar
dot dot dot ...
He's got an 02 or 03.
Old Jul 24, 2008 | 02:45 PM
Feldman's Avatar
Sounds like it is something else, but have you checked if your security light is going solid when you try and start it. If so you have a NVIS problem. I just had that problem and it allows the car to crank and fire for a second some of the time but then immediately shuts it down. (in normal operation the security light should go out when you start the car)
Old Jul 24, 2008 | 02:49 PM
NmexMAX's Avatar
dot dot dot ...
It's not an NVIS problem because it actually starts, just doesn't stay on.
Old Jul 25, 2008 | 01:53 PM
eyecon7's Avatar
YEa.. I havent touched the IM either... it started the other day... its just been sitting in the drive way cause i had bought a GS recently... and my cv joints are gone as well.... its an 2003 with SSIM and HEaders... i also removed the GAB like 3 months ago and put it back to Stock... I called Nissan they said the TB's have a problem and its 140 for a remanufactured TB
plus Exchange
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
