Oil leak...damn!
Da Roller Coaster!
Oil leak...damn!
I have a very small oil leak that looks to be right at where the engine is mated with my auto tranny. It is coming from under a small cover on the engine next to the cross-member. A picture of the area is attached. Does anyone know what this is? Anyone have this leak before? What would it take to repair it?
I aplogize for the crappy picture quality, but it was at night and I was taking it with my cell phone using a flashlight for light, HA! Hopefully it is clear enough to where someone can provide some input.
Thanks....
Thanks....
RMS (rear main seal) is leaking.
You are not alone, I have had this for the past 50K miles... I don't intend to fix it till I loose 1Q a week and see a puddle under the vehicle. I have had the leak under control using HM oils.
Da Roller Coaster!
Hmmm...damn. I guess I'll just check with the shop because I am leaning on taking my Max in for the ball joint replacement anyhow.
Right now I'm only losing about 0.25 quarts between oil changes so it really is not a bad leak at all. It can stand to be left alone for a while until it becomes a bigger issue, it just annoys me.
instead of the engine pan, my tranny pan is oily. servo gasket and pan gasket need to be replaced soon, so do the valve covers.
Chances are slim that it's the RMS itself, anyway. More likely to be the upper oil pan gasket directly beneath it.
actually, RMS is failry easy to do your self. or to me anyway. it could be the oil pan leaking, or the rear main. eatherway both should be changed. IMO
the motor def does not have to be pulled. thats the dealer trying to stick it to you.
i have changed a rear main, and oil pan gasket. in my backyard, in about 8-10 hours from time driven in yard, to time it was driving out.
thats 3.5 idk if there is a diff.
oh ya, and most of the time if its RMS it will leak when the motor is running. and when its shut off it may or may not leak.
but if its oilpan leaking its mostly leaking while jus sitting there.
someone chime in if im wrong
I'd try a high mileage oil and see if that helps, at the price the dealer wants, I'd just go ahead and get a low mileage use engine and swap it in when the oil leak gets real bad. More initial cost but unless your mileage is pretty low, I couldn't see dropping a grand on the engine for just a gasket replacement. Rather add the cost of a lower mileage engine on to the bill at that price.
Da Roller Coaster!
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
