broken sunroof - gets stuck
So the sunroof will tilt up and down no problem,..but, when I try to fully open it, it drops like normal begins to slide back and after maybe a few inches it just freezes like one of the rails is out of line... anyone have this and/or have a fix besides replacing the entire hardware.. thanks in advance (5.5gen btw)
Search and you shall succeed
I have to guess and say you disconnected your battery in the last few days and this is why your sunroof is stuck.
i had the same problem, next time search
page 2-29
RESTARTING THE SUNROOF SLIDING SWITCH:
The sliding switch will become inoperable after the battery terminal is disconnected,the electrical supply interrupted and/or some abnormality detected. Use the following reset proceedures to return sunroof to normal:
1. If the sunroof is open, push the tilting switch repeatedly towards tilt DOWN to fully close the lid.
2. After the lid has closed all the way, keep pushing the tilting switchtowards tilt downfor more than 1 second.
lol ^^ thanks but no, thats not the case..... the problem is.. it seems as if one of the rails/tracks are bent/broken/out of line.. the sunroof tilts fine.. but when opening.. it starts to open then goes ERR and stops moving, like its getting stuck or it is forcing against something causing it not to open..
i'll look in depth into it tomorrow about the groove so if the groove is narrow u htink i can bend it back? .. no i havnt tried to grease it up but it seems to be full of grease..thanks for the response
My sunroof just opens whenever it feels like it, scares the crap out of me. So far it's never done while raining!! I just slide the switch to open and then close, and the sunroof shuts again. It's done this about 3 times in about a year. Anyone elses sunroof posessed?
Joe.
Joe.
It's happened to me a few times. I think there may be something in the owners manual.
How I fixed it.
1) open the roof all the way, even if it takes several presses of the button.
2) remove the key from the ignition for a few seconds.
3) close the roof.
4) remove the key from the ignition for a few seconds.
5) Tilt the roof all the way up.
6) remove the key from the ignition for a few seconds.
7) close the roof.
You may have to repeat the process.
How I fixed it.
3) close the roof.
7) close the roof.
thanks^^ but i cant even get it to open all the way.. it starts to open and then !@#$#$^$%&%^* as if there is something blocking it not allowing it to open IE bent rail .. or ect..any more advice?
Sunroom still stuck
My 2006 Maxima still does not work. I have tried the reset everyone mentions to no avail. What mine does is just click. I can hear it click about where the motor is. I am not sure if this is a relay or what. Any other suggestions?
tarun900
19
12-20-2021 06:57 PM
RealityCheck
10-02-2015 06:34 PM
HerpDerp1919
09-29-2015 02:02 PM
