driving under 1000 rpm
Old 08-09-2008, 08:01 PM
yogi's Avatar
so today got into my max, started fine, SES comes on, and the car wont go above 1k rpm...limp mode
drive home took 30 min (2 miles away)
any ideas why?
I`m thinking bad MAF but i want to be mistaken ( $$$ on 03)
I've tried pulling codes per http://www.technosquareinc.com/350reset.htm but with no success, does anybody have a different procedure for that?
yogi is offline
Old 08-09-2008, 08:43 PM
HDB Audio's Avatar
I think your not mistaken..loll... I think its a bad MAF too.
HDB Audio is offline
Old 08-09-2008, 08:46 PM
yogi's Avatar
bastard
I know i can put a 00-01 MAF on...am i correct?
00-01 MAF = less $$$ then 03
yogi is offline
Old 08-09-2008, 09:08 PM
yogi's Avatar
besides HBD Audio....
bump...
yogi is offline
Old 08-09-2008, 10:22 PM
jasonmax's Avatar
have the codes pulled out.
jasonmax is offline
Old 08-09-2008, 11:51 PM
sunstream453's Avatar
use the procedure in the how-to sticky. its super easy to read the codes using the normal procedure
sunstream453 is offline
Old 08-10-2008, 05:14 AM
johnnyd2k2's Avatar
Originally Posted by yogi
bastard
You can you just need to remove the IAT sensor from the 2k2 MAF and put it into the 01 MAF here's a link that should help go to the last page post #89 tells you how to do it.
http://forums.maxima.org/5th-generat...r-2k1-maf.html
johnnyd2k2 is offline
Old 08-11-2008, 10:15 AM
yogi's Avatar
Found the following codes
P1122 - Electric Throttle Control Performance Problem
P1126 - (2002-2003) Throttle Control Motor Relay Circuit Open
both of the show up twice..(P1122 x2 and P1126 x2)
What do you guys think might be the problem...i have a new MAF for replacement if necessary...but per codes i don't think its a MAF
any suggestions?
yogi is offline
Old 08-11-2008, 10:30 AM
cleaned your throttle body recently?
the reason they show up twice is that they keep repeating. if you watched long enough they would show up 100 times
Old 08-11-2008, 10:49 AM
yogi's Avatar
"the reason they show up twice is that they keep repeating. if you watched long enough they would show up 100 times"
gotcha...
regarding cleaning - nothing was done to the car recently...
The SES just came on and the limp mode happened hehe...
Update: left the car overnight and right now its running normally (with the SES on)
yogi is offline
Old 08-11-2008, 11:03 AM
well 1000rpm is below limp mode (2500), which to me means that the throttle body just wasnt responding. that probly could mean several things, either the TB is on its way out or it was throwing a temper tantrum and is fine. i guess youll find out soon enough. lol
Old 08-11-2008, 11:17 AM
yogi's Avatar
throttle body? ouch...
yogi is offline
Old 08-11-2008, 11:23 AM
not so bad if it turns out to be fine. i would reset the ECU or leave the battery disconnected for a couple days, then do all the relearns. it would be unusual for a throttle body to crap out without having been messed with
Old 08-11-2008, 01:12 PM
jasonmax's Avatar
check connection, maybe?
jasonmax is offline
Old 08-11-2008, 06:53 PM
lalaMAX's Avatar
the "drive by wire" thing... i had seem exactly the same on a pathfinder
lalaMAX is offline
Old 08-11-2008, 07:01 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
MAF
Lontar1 is offline
Old 08-11-2008, 07:03 PM
wat
AceofSpds's Avatar
unplug MAF to see if it runs the same, if so replace maf
AceofSpds is offline
Old 08-11-2008, 07:18 PM
yogi's Avatar
Have the new one at home...will unplug tommorow and we'll see what happens,
update to come
thanks so far
yogi is offline
Old 08-12-2008, 01:52 PM
dewd's Avatar
Best advice for testing your MAF
dewd is offline
Old 08-12-2008, 03:24 PM
jasonmax's Avatar
I don't think it's MAF related. the problem is that the throttle is not getting signal.
jasonmax is offline
Old 08-12-2008, 07:06 PM
sheabny's Avatar
my best guess is that . ur TB is ded ...!
sheabny is offline
mvm062
11-30-2020 09:00 AM
captchaos
03-15-2016 12:18 PM
bryants95max
10-02-2015 12:52 PM
slowlifer
09-08-2015 05:53 AM
dcardello
09-03-2015 11:44 PM
Quick Reply: driving under 1000 rpm
