will a 2003 maxima's abs sensor work on a 2001?
Old Aug 22, 2008 | 03:47 PM
imported_D_Roc's Avatar
i had to change the knuckle on my car the front left and the one i got was from a 2003 maxima and it came with the abs sensor (my old one broke while tryign t o take it off) but i realized the socked of the sensors were different, so i cut the old sensors adapter and hooked it tot he new one and after that i had the CEl, ABS, Slip and TSC off lights and i erased them now i get all those lights except the cel so when i hook the obd scanner it says no code found what went wrong?
Old Aug 22, 2008 | 04:13 PM
VQP0WER's Avatar
I'm showing that the sensors are the same on 00-03 models. Your scanner will not give you ABS codes, you need the Consult tool I believe (dealer). The sensor is probably not aligned properly with the teeth.
Old Aug 23, 2008 | 08:15 AM
so i have to go to the dealer to get it reseted? how much will it cost? also i drove the car like 2miles with the left side sensor unplugged
mrc00l88
Jan 25, 2024 01:14 PM
ah2002
Mar 9, 2016 01:42 PM
District
Aug 15, 2015 08:23 PM
09maxshawn11
Aug 9, 2015 01:13 PM
kenc15
Aug 5, 2015 08:29 AM
