Gerbils under my dash??
Old Sep 4, 2008 | 01:47 PM
ptspringer's Avatar
When I turn on the fan or AC. The blower motor or some other contraption under my dash makes an intermitant squealing or warbling sound, like gerbils running on a rusty run wheel.
If any of you have experienced this, I'm sure you know what I'm talking about. It makes me want to turn off the AC.
It sounds like a dry or bad bearing on the blower motor - or maybe some foreign objects in the air line.
Is there a way to lubricate the offending bearing w/o tearing apart the air system?
Help would be much appreciated,
Paul
2001 Nissan Maxima
Old Sep 4, 2008 | 07:53 PM
tntmaxima's Avatar
well dude i had a similar situation just recently and it was just the belt needing to be tighten after recently changing the harmonic balancer.......
Old Sep 4, 2008 | 08:46 PM
flatcat19's Avatar
I recently replaced a blower motor in my Maxima, due to the same sound. Bueno.
Old Sep 4, 2008 | 09:03 PM
Peanuthead's Avatar
There is a TB article on this but I don't remember the number of it. I have the same problem in my '01.
Old Sep 5, 2008 | 12:25 AM
CMax03's Avatar
Paul
2001 Nissan Maxima
You sure it's not the A/C compress clutch? Nissan seem to start making noise after a few tens of thousands of miles. the bearing is replacable but the dealer normally replaces the entire compressor!
Old Sep 6, 2008 | 12:10 AM
dnozzle2789's Avatar
you never know till you look
i bought my max used...previous owner had a bunch of curious kids...i had a similar problem with noises all over the a/c system when it was on..looked over it extensivley and found everything from hickory nuts, peanut shells, nickles, a marble...etc.. lot of sounds coming from that housing that holds the passenger and drivers side fan for the footwell under the dash...
Old Sep 6, 2008 | 06:10 AM
rvamaxima's Avatar
PM me if you need a blower motor. I have one in good condition off an 01.
Old Sep 6, 2008 | 06:54 PM
CMax03's Avatar
There should be a 3 or 4 bolt panel to remove the blower and clean out the housing of leaves, acorns, rat droppings, etc
Old Sep 7, 2008 | 07:01 AM
ptspringer's Avatar
Thanks for the replies.
I'm pretty sure that it isn't the AC compressor since it comes on with the fan even when the air conditioner is off. Same with a loose belt.
Seems to be associated with running the fan - either the motor - or because of the air running through the ducts.
I will look for the cleanout panel and see if perhaps there is debris in the line.
Is it difficult to replace the blower motor?
Old Sep 7, 2008 | 07:32 AM
jasonmax's Avatar
nope, it's very easy. take out the glove box, unscrew three screws, unplug the plug, put new one in, and you know how to put them back again.
Old Sep 8, 2008 | 08:21 AM
ptspringer's Avatar
I removed the blower motor and cleaned it. No foreign objects found in the line and the blower seems to run strong with no hint of a warble.
Will put my ear to the A/C compressor and also the blower motor when the noise starts again.
Also I'm not sure I've really ruled out the A/C after all. I will turn off the A/C when the noise is present but leave the fan on.
Old Sep 8, 2008 | 08:38 AM
Feldman's Avatar
was the noise present with the a/c off but the fan on? That would be one easy way to narrow thing down...
Sounds like the blower to me though, after time the bearing wears out and starts to make the exact noise you are describing
Old Sep 8, 2008 | 09:08 AM
streetuner's Avatar
i get this noise from time to time...very rare for me...only when the A/C is on i have the noise
Old Sep 10, 2008 | 10:00 AM
ptspringer's Avatar
Well the noise came back and I was able to run with and witout the AC on. The noise is definitely from the blower. Happens with the AC off.
Where's the best parts store?
Old Sep 10, 2008 | 12:35 PM
XGaSpAcHo's Avatar
i have the EXACT same problem! only makes noise with the AC on. sometimes is sounds like a squeaking noise and other times it's a louder, deeper buzzing sound almost.
have you figured anything out yet?
Old Sep 11, 2008 | 01:26 PM
Feldman's Avatar
I bet rock auto has them and they seem to be about the cheepest out there. Auto zone or a local parts store would probably have one. I seem to remember buying a replacement blower for my accord from auto zone a few years back.
Old Sep 11, 2008 | 02:32 PM
Bradbmx1's Avatar
same here.... haha
Old Sep 12, 2008 | 08:57 AM
CMax03's Avatar
Clean your fan housing, possible leaves, debris, rat droppings, etc...
Old Sep 12, 2008 | 04:20 PM
nsnrider's Avatar
they also sell the blower motors on ebay...
Old Sep 17, 2008 | 12:37 PM
MaxManOhio's Avatar
Thanks for this info... Mine makes the same noise...
Old Sep 17, 2008 | 01:12 PM
XGaSpAcHo's Avatar
Originally Posted by Bradbmx1
same here.... haha
any idea what's causing it? have you tried anything?
Old Sep 19, 2008 | 08:47 AM
XGaSpAcHo's Avatar
i spent some time working on the issue this weekend. took the blower out and apart. then lubricated the motor. so far the noise is pretty much gone. i'm probably going to libricate it again at some point this weekend to eliminate it completely.
Old Sep 21, 2008 | 09:20 AM
XGaSpAcHo's Avatar
ok well i guess lubricating the motor was a bad idea because as of yesterday afternoon my blower completely stopped working
Old Sep 21, 2008 | 09:23 AM
XGaSpAcHo's Avatar
can anyone recommend a place to buy a new blower motor assembly? i looked on ebay and they have an aftermarket one for around $50. if it's not too much extra i think i'd rather get a genuine nissan one.
Old Sep 21, 2008 | 10:34 AM
jasonmax's Avatar
no, those motors can't be lubricated. I tried, and mind died even faster.
mine put too much current on the system, it kept poping fuses, and after 5 sets of fuses, the motor amp died too.
Old Sep 21, 2008 | 10:35 AM
jasonmax's Avatar
for a new on, it's about $250.
Old Sep 22, 2008 | 06:51 AM
XGaSpAcHo's Avatar
where were you last weekend before i took the whole thing apart and lubricated it?!
so you're saying it could be the fuse and not the actual motor that's blown? but then again if i replace the fuse it will just blow again, right? i guess i need a new motor now.
Old Sep 22, 2008 | 06:55 AM
XGaSpAcHo's Avatar
that's just great. i saw them on ebay for around $50 for an aftermarket one
http://cgi.ebay.com/ebaymotors/2000-...mZ120306499902
is this a bad idea?
or they have one that came from a totalled car for $100
http://cgi.ebay.com/ebaymotors/HEATE...mZ160285263269
or autozone has is for $115.
http://www.autozone.com/R,114944/sto.../addToList.htm
i can't decide which one to get. i'm leaning towards autozone.
Old Sep 24, 2008 | 06:53 PM
ptspringer's Avatar
Well, I replaced the blower motor and it's as right as rain (that means it's good)
I got mine from ebay - from TVC like the one in previous post.
Seems to work fine, although mine was slightly damaged in shipping. All the blower motors are aftermarket
Gerbils are gone!
Old Sep 24, 2008 | 07:07 PM
XGaSpAcHo's Avatar
Gerbils are gone!
i was hesitant about buying from ebay because it wouldn't have any kind of warranty on it. with my luck it would break a month later. ended up buying mine from autozone with a lifetime warranty.
Old Sep 24, 2008 | 08:01 PM
CMax03's Avatar
Gerbils are gone!
Did you have alot of leaves and debris at the cabin filter, evap, and blower motor? I just chg'd my cabin filters this past weekend and there was quite alot of leaves. But I vacuumed and blew it all out and even made sure the drain was clear and free of obstructions!
Old Sep 24, 2008 | 08:10 PM
MaxSE2001's Avatar
i have a similar problem its a rattling constant noise coming from a/c compressor and gets quieter when i turn the a/c on. but a mechanic says its the bearing inside the compressor that breaks when its old.....can anyone help me out?
Old Sep 24, 2008 | 08:16 PM
CMax03's Avatar
My a/c compressor makes a slight little scrapping like sound! ( it's only heard when next to a curb It's the bearing and the stealership changes the entire compressor...It's only about $450 minus labor....Mine is staying on until it breaks!
Old Sep 24, 2008 | 08:26 PM
Feldman's Avatar
Spend the little extra and get one from auto zone. that way you have the piece of mind of the lifetime warranty and you will have it now!
Old Sep 24, 2008 | 08:33 PM
XGaSpAcHo's Avatar
already did. it wasn't that much more but it was about twice the price of the ebay one. and they don't stock it. so they have to special order it and it comes in the next day. shipping is free though and i can return it for whatever reason.
it's part number PM2729 from autozone in case anyone needs it.
Old Sep 24, 2008 | 11:05 PM
MaxSE2001's Avatar
i couldnt say it any better but mine started low and now noise has increased dramatically but yea staying on....is there any way to repair it wit out changing the whole compressor??
Old Sep 24, 2008 | 11:06 PM
MaxSE2001's Avatar
lol i work for autozone ima check that part out 2maro....
Old Sep 26, 2008 | 01:16 PM
XGaSpAcHo's Avatar
i picked mine up yesterday. and you have to splice the cables to hook it up. i don't want to do that. i was hoping it would have an OEM connector. looks like i'm going to have to return it and get the ebay one.
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
