tranny issues
Old Sep 27, 2008 | 10:50 PM
navigator82's Avatar
tranny issues
im concern about my maxima transmition, in 2nd and 3rd shift is litle harder anyone with this problem, wath can i do to solution the problem with out new tranny
Old Sep 27, 2008 | 10:57 PM
Feldman's Avatar
manual? auto? have you changed your fluid lately? how many miles are on it?
Old Sep 27, 2008 | 11:32 PM
auto and yes i chance the fluid and still doing the hessitation 101k
Old Sep 28, 2008 | 01:56 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
TCM and or Selenoids....
Old Sep 28, 2008 | 03:38 PM
so i have to take my car to the sthealer for a check up or i can fixed my self
Old Sep 28, 2008 | 04:52 PM
Lontar1's Avatar
you can do the TCM replacement yourself as well as the selenoids.. but you need a true check up .... so your decision...
Old Sep 29, 2008 | 01:14 PM
perkman87's Avatar
is there a check engine Light on, if so bring it to Autozone let them run it then get the sensors from nissan, or someone on the forum, my 03 max A/t was doing the same thing. ... It came to the point that it would just freely revand not go into gear, swapped out both sensors and did a flush, totally fixed the problem.... the A/T light still blinks when i start it but it is driving fine.
Old Sep 29, 2008 | 01:16 PM
808MAX-SPEC's Avatar
Double check your trans fluid levels.
Old Sep 29, 2008 | 10:31 PM
i check the fluid like for 3 days in a row and is good and, i have no lights on is the reason im litle scare maybe if someone can helpme with pictures or explanations of who to chanc=ge the sensor i could work on change them please i need help
Old Oct 3, 2008 | 10:25 PM
man i get my maxima to the shop and after many test i have the results........ i was to much presion so they have to open the transmision and diggin for resolv the problem..thanks for you help
Old Oct 4, 2008 | 09:27 PM
jasonmax's Avatar
mine jerks between 2nd and 3rd, no revving problem just takes longer to shift than other gears.
Old Oct 4, 2008 | 10:53 PM
jason so bad to hear these man bout the seam thing hapen to my transmission and is wth reason i take the car to the shop
Old Oct 4, 2008 | 11:00 PM
jasonmax's Avatar
waiting for your result.
Old Oct 11, 2008 | 12:00 AM
i just got my car and is not like the i xpect is runing stronger but the 2nd shift still litle harder these is normal i think they make a rebuild in my tranny and is expensive but i think is whort the money
Old Oct 11, 2008 | 07:08 AM
Blitzfist's Avatar
dont rebuild your tranny over this. Mine does the same thing between 2nd and 3rd its just like maybe a half a second longer to shift then the rest of the gears. The stealer checked it out a while ago and said don't bother. your tranny will be fine
Old Oct 30, 2008 | 10:54 PM
03jmax's Avatar
My 03 max has 133k I just got it don't kno if the tranny oil ever been changed but its kinda dark in color so I don't kno about changing it . I have a a/t what do u guys think I should do what signs should I look out for before my tranny can mess up with that oil since there's no promise its gonna be ok after I change the oil. I mean I've been feelin the car shift a little harder and heavier then before but I'm not sure don't want to think anything bad
Old Oct 31, 2008 | 12:09 PM
You said your fluid is dark. If it's redish brown or brown, change it ASAP. Check out Lontar1's link above. If you're not brave enough to drop the pan, just do a fluid change.
Old Oct 31, 2008 | 03:09 PM
Blitzfist's Avatar
well i dont know how true it is but I was told if your tranny fluid was never changed past 100,000 miles then leave it along. When I changed the tranny fluid things got worse. Went from a rough shift to a slip. Not sure if it was just a coincidense though
Old Nov 2, 2008 | 04:22 PM
03jmax's Avatar
So if my car shifts a little harder in gears does this mean anything . I don't kno I really wonna do something but just don't want the tranny to go I don't kno how the last owner treated the car but. Ib would like to change the fluild .
Old Nov 2, 2008 | 04:57 PM
sublime258's Avatar
I am in the same boat, I have an '02 GLE with about 79k on it. My tranny has been slipping from 2nd to 3rd gear bad, especially when it's cold, even after warmed up. I did a transmission flush with Amsoil ATF a few months ago, and it seemed to make it worse. When it is in between shifting from 2nd to 3rd, not only is it very slow, but the RPMs spike up about 400 or 500 then drop back down once it gets into 3rd...definitely not good for the transmission. I was about to drop my car off at the stealership last week, but it warmed up outside and it wasn't shifting as bad. I am going to wait until it gets colder so that they can really see how bad it's slipping. Hopefully this is nothing too serious, and a new TCM or solenoids will fix the problem...
Old Nov 2, 2008 | 06:12 PM
Blitzfist's Avatar
i'm probably eventually getting mine rebuilt. my fix was to let the car warm up to full temp(leave it running about 5min before i leave) and go very easy on it. Also if mine is still cooler i just take my foot off the gas right when it would shift and that avoids the slip. when the tranny slips it causes dangerous overheating withing the transmission and can cause greater damage. I've put about 1000 miles on my car since the slip started and so far what i;ve done is well preserving it.
Old Dec 14, 2008 | 08:40 PM
after two months of fixin my car i don't know if is ok......... when i press the gas ilittle heavy is little harder in 2nd but when i drive normal speed or not rush everything is nice and smoothso i consider my investment good anyways i got 1 year warranty...... the problems whith mi car was the selenoids,clutchs(never know A/Tgot clutchs),valve boby and many other things. i just thing the person who was the owner before my never chec in the mantenance of the car i bugth my car w.92mls
good luck whith your's car and give good mantenance this car are here forever '''maxima'''
Old Dec 14, 2008 | 08:48 PM
jasonmax's Avatar
I guess almost every auto maxima has this problem. it's not about maintainance.
Old Dec 15, 2008 | 07:55 AM
Torgus's Avatar
ohhh! another tranny thread!
Old Dec 15, 2008 | 08:00 AM
Scottwax's Avatar
That's Mr. Detail to you
Most likely a valve body problem if you have a cold temperature slip. Once the transmission warms up, the clearance/sticking issues goes away and it shifts properly. If it was the clutch packs going out, it would get progressively worse (day to day) and be worse the warmer the car got.
I am sure Nissan knows about this problem because in the FSM it says to perform testing with the transmission at full operating temperture. Sneaky way of not having to replace transmissions, eh?
Just take it easy, maybe lift a bit right before the first few 2-3 upshifts and you should be fine. I noticed soft shifts on the 2-3 when the car was cold when I bought my car and 28,000 miles later, I haven't noticed it getting any worse so it is something I will just live with.
Old Dec 15, 2008 | 02:07 PM
sublime258's Avatar
Just wondering, does anyone think the dealership would actually come to the conclusion that a TCM would need to be replaced? Or do you think they would try to blame it on something else? Just wondering because I'm still under extended waranty and am hoping whatever the problem is, is covered.
Old Nov 4, 2010 | 10:52 AM
jvrobert's Avatar
Since I can't post a new thread, resurrecting this oldy.
My 2002 GLE is having the exact same issue. I live in Arizona and it just started cooling down (a bit), and in the mornings mainly my transmission slips from 2nd to 3rd gear.
Dealer replaced wiring harness of all things (and charged me $350) and this didn't solve it at all, the next morning the same thing happened. My Service Engine light turned on, and when I first start the A/T light turns on for a few seconds.
Now the dealer wants to charge me $650 to replace the TCM. It made no sense to me that temperature expansion issues would trigger something in the TCM.
Any ideas on how I should proceed? I'm thinking of just telling him to cancel TCM order and taking it somewhere else, but it seems like a sneaky problem and I haven't seen any definite solutions. Maybe I can just live with it and let up off the gas when it's about to shift from 2nd to 3rd gear, that seems to alleviate the issue.
pktaske
May 6, 2016 07:49 AM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
