bearings wearing out, is this common on maximas and at what mils does it happen
Old Oct 24, 2008 | 03:49 PM
imported_D_Roc's Avatar
the bearings on both side on my 01 max is worn out both front is this a common problem my car has 138k miles and i also have a 1998 max with 253k miles on it and it never had any serious problem like my 01 at all. so is this a common problem on this car did it happen to you and at what point did it happen
thnaks
D
Old Oct 24, 2008 | 04:44 PM
pmohr's Avatar
No more Maximas...
Wheel bearings, strut mount bearings...?
Old Oct 24, 2008 | 05:39 PM
blkAEmax82's Avatar
Glory Glory Man United
My passenger is done for, I have about 150,XXX+ miles . Will be doing both Left and Right side ASAP !
Old Oct 24, 2008 | 06:42 PM
wheel bearing
Old Oct 24, 2008 | 07:02 PM
moogotzskillz2's Avatar
i'm havin the same problem and i nkow its a common aproblem. but my car has a very loud Humming noise? so i think i should replace the hub not just the bearing right???
and where is the best place to get hub assembly from??
Old Oct 24, 2008 | 08:15 PM
Scottwax's Avatar
That's Mr. Detail to you
You can replace the wheel bearing only as long as the hub isn't damaged. Wheel bearings seem to be a common issue with 5th gens. I had one bearing go out soon after I bought the car. The brakes had been done just before I bought the car and it appears when they serviced the bearings (repacked them), they did not adequately retighten the lock nut to the required 240 lb-ft of torque. The nuts backed off and it ate the driver's side bearing. The left side hadn't backed off nearly enough so that one was okay.
Old Oct 24, 2008 | 09:31 PM
CMax03's Avatar
If you want the same exact bearing that Nissan carries go to NAPA and save some bearing...
CRizz
41
Jun 7, 2021 05:42 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
laparka66
Aug 6, 2015 09:36 AM
