exhasut noise inside the cabin
Old Oct 29, 2008 | 12:43 AM
gunmax's Avatar
sup fellow orgers.... i was wondering if anyone tried putting dynomat to reduce exhaust noise? i have a full greddy catback and i could care less about the noise outside but tryin to reduce the noise inside.....
Old Oct 29, 2008 | 01:47 PM
gunmax's Avatar
has anyone put dynomat in thier car????????
Old Oct 29, 2008 | 01:56 PM
Drockb418's Avatar
nope, its a new idea no one has ever tried it
Old Oct 29, 2008 | 02:53 PM
lowincash's Avatar
No More Maxipad
just do yourself and others a favor and get a quieter exhaust if you not then get stock one...it's quiet =) is your greedy exhaust those loud ones that set off car alarms when you drive by? i hated those =/
Old Oct 29, 2008 | 03:57 PM
mymaxi41691's Avatar
is he bothering anyone?
Old Oct 29, 2008 | 04:01 PM
n3985's Avatar
大陆弟弟
I tried with 2x of Raam BXT and 1x of eDead Teklite in the trunk, doesn't help did remove the occasional rattle though!
Old Oct 29, 2008 | 04:17 PM
l3ftonm3's Avatar
You could try some exhaust wrap. After you apply it and it dries spray it with high temp paint to seal in the pores of the wrap to not let moisture in. If you want to get really paranoid after the high temp paint dries spray the exhaust again but with that high temp silicon spray that comes with the dei kits. Or just get a quieter exhaust, lol.
Old Oct 29, 2008 | 05:05 PM
gunmax's Avatar
ok... hahah. naw this exhaust aint that type but it quiets down at higher rpm. btw i love this exhaust and tell me do u have those alarms that are so sensitive it irritates its own owner.... i still hate those
Old Oct 29, 2008 | 05:08 PM
gunmax's Avatar
ok.. that sounds like too much work. but thanks anyways on your input. anybody know any "Quiet mufflers" that still look clean and sounds clean... maybe the cattman?
Old Oct 29, 2008 | 05:11 PM
dineth00i30's Avatar
sell me your cat back for a good prize and buy a cattman.! Problem solved right?
Old Oct 29, 2008 | 05:27 PM
gunmax's Avatar
make me an offer! ill check the receipt for the price i paid for and when i bought it....
Old Oct 29, 2008 | 07:30 PM
CMax03's Avatar
WTF????
Old Oct 30, 2008 | 02:36 PM
sublime258's Avatar
Quiets down at higher RPMs?? I have an EVO2 and mine is definitely quieter at lower RPMs. And by the way...this is hardly a loud exhaust at all.
Old Oct 30, 2008 | 03:48 PM
Scottwax's Avatar
That's Mr. Detail to you
Add a resonator to the exhaust. Problem solved. Usually.
Old Oct 30, 2008 | 04:32 PM
boondoxmax's Avatar
that's why i stayed away from performance exhaust. too much noise..........
Old Oct 30, 2008 | 07:25 PM
gunmax's Avatar
theres a resonator on the catback piping...??? add another one?... u know what.... my question is quite simple.....
DOES ADDING DYNOMAT HELP REDUCE SOUND FROM THE EXHAUST?
Old Oct 30, 2008 | 07:28 PM
gunmax's Avatar
I HAVE THE SAME ONE.... i know its not that loud but i would like it a little quieter in the cabin.... my exhaust is really deep when u open the throttle at higher gear. Now if yours differs than obviously our engines are different and u cant relate. thanks anyways on your input.
Old Oct 30, 2008 | 08:48 PM
/b/'s Avatar
/b/
No. You need a closed foam sound barrier. Check out SecondSkin.com
Old Oct 30, 2008 | 09:26 PM
Scottwax's Avatar
Yes, but a resonator (if the exhaust doesn't already have one) will probably be a cheaper solution. You'd have to take out your seats and carpet to lay it down too.
Old Oct 30, 2008 | 09:51 PM
/b/'s Avatar
/b/
It doesn't, my friend...I speak from experience, I wish it did.
Old Oct 30, 2008 | 11:22 PM
gunmax's Avatar
so a resonator doesnt work or dynamat doesnt work?
Old Nov 1, 2008 | 06:09 PM
irish44j's Avatar
retired moderator
do some research. dynamat is not to quiet the interior of the car really. there are better sound insulators than that.
from one of the gurus of deadening, Raam audio (applies to my subaru, but maxima should be similar).
Deadening just the trunk, even the rest of the car, may or may not do all you want as loud exhauast is of very high acoustical energy and permiates the air all around the car, coming in from everywhere.
It depends also if loud all the time or at a certain RPM but in the end, we all have different levels of acceptance so you can try it and see how it turns out for your needs.
If you deaden the hatch, some of the rear sides, rest on the floor and cover it all with Ensolite you will get the best results, this order should be plenty and add only 12 lbs or so at the most.
1.2 roll BXT RAAMmat 49.50
2 yards ensolite 19.90
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
